bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
How close do you get?
Hard to see on the picture, but there is some copper showing through.
The neutral appears bare or partially bare, but that is okay. Some are installed bare to begin with. The hot legs don't appear to have any bare spots, but will certainly be brittle. Disturbing them can have some spectacular consequences if any of the insulation cracks off.
Given the apparent age of that installation, it's nearing the end of its service life anyway. Additionally, the inproper flashing around the service mast concerns me. That's a 20 year roof with 5 year Blackjack smeared around the mast. Hate to see that sort of work. A proper split boot should have been utilized when the roof was replaced last. |
The hot leg has a bare spot on it. About three inches long.
Ben,
It also appears that their are little or no drip loops on these conductors and what was the clearance from the service points to the actual roof itself. All these things need to be noted as well in ordered also build a basis for the client having it replaced. But most certainly in the LEAST....defer for electrical evaluation. Paul W. Abernathy |
Ya, I posted the picture to see how close other inspectors get to weather heads, and why they should. My electrical license is still goog here in Tn, but thanks for all the replys.
Now see ben....if you had not inspected it...you could have picked up a few bucks fixing it...ahhh but now you can't...Conflict of Interest...
You are correct however....in that in the past seminars I ask guys if they actually check the mast head when available....90% did not until I explained to them it may be helpful in sizing the service...since most of the time the mast is under the installation habits of the Electrician and not the POCO..atleast it is where I come from....just installed one on Friday.. great picture and does serve to show guys......you have to be careful but most certainly they need to pop that ladder up and check the connections at the weatherhead....never know what you will find lurking their.... Paul W. Abernathy |
Ya, I try not to fix them any more. THe going rate for an upgade to a 200amp service would be between 1000 to 1400. Not Enough for me and my talent. HA
I also did 95 percent commercial and industrial. I never really liked doing residential wiring. My favorite job was probably a grocery store I did. There was more crammed into it than most factories I have wired. I also ejoyed remodeling 2 hospitals. The regular, emergency, critical, and life safety, branches of power made it very interesting. Not to mention all the generators.
I also did a data center for a bank. It was also crammed packed. |
Here are some pictures from the last job that I did. THis is the job where I injured my shoulder. I will be having my 3rd surgery in January. Yes, I am dredding it already.
Wow...fella you have dabbled.
I have been primary in Residential since 1993 but before that I wired the Lexus building in Charlottesville, VA....they print law books and used to be Michie Publishing. Had my fun with large CT Cabs and endless runs of 4" Rigid.....OH I am SOOO glad those days are gone...I kinda like residential but these days they are all high dollar homes and we are really getting into data control systems and home automation....neat stuff. Now I did not mind doing the strip mall shops...did quite a few of those...man they are easy.....plans may give you 10-15 receptacles in the whole joint and mostly lighting and whamo....DONE......most of the time the engineering specs layed out our entire electrical plan.....no brainer just do what is on the print. I like residential because I can be creative....yet use it to teach my guys also ...but winter is here.....not LIKING rough in's as of late.... Paul W. Abernathy |
OOPs, left out the picture.
and some.
Another weather head.
| House Wrap | brepanshek | Exterior Inspections | 26 | 10/4/08 9:45 PM |
| Sprinkler heads in Suspended Ceilings | mcyr | General Inspection Discussion | 9 | 7/22/07 5:39 PM |
| Vinyl siding installation guide | badair | Exterior Inspections | 18 | 3/27/07 5:38 PM |
| Weather head | dmacy | Electrical Inspections | 3 | 2/8/06 7:19 AM |
