Inspected a 3 unit condo (new construction) and the service drop goes to the weatherhead at the same level as the 2nd floor (my client's level) back porch deck.
I could easily reach out and tough the conductors without even touching the railing. Drip loop bottom was 4'11" above the porch deck floor level. The back porch (structure) is steel and the decking is treated lumber. Remember, this is in Chicago, where the porches themselves are dangerous Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
I think you would be hard pressed to find anything prohibiting that installation except for maybe this. . .
One point is that the POCO hooked up to it. You would think that they would not have if it was bad. Probably like the idea of not haveing to use a ladder or basket. Just connect it from the back porch.
2003 IRC E3504.1 Clearance from building openings. Open conductors and multiconductor cables without an overall outer jacket shall have a clearance of not less than 3 feet (914mm) from the sides of doors, porches, decks, stairs, ladders, fire escapes and balconies, and from the sides and bottom of windows that open. See figure E3504.1
I can scan and post the figure if needed. |
Michael, that code section is basically NEC verbatim. It applies only to conductors along side these areas.
This requires 10' vertical clearance, and this 10' clearance must extend 3' out horizontally around the area. |
Maybe I misunderstand the photo. I was under the impression that this picture was taken while standing on a 2nd floor balcony. The cables would then be somewhere around 15' off the ground below so the >10' requirement above a walkway would be met it would seem. Now, I'm not sure what the technicality is regarding 'sides of these areas'. It would sure seem to me that the cables don't meet that requirement at all. They are "along side of those areas", aren't they? If this photo is taken from ground level then never mind, my assumption is wrong.
Here is a similar one.
Stairway leads to access for a 2nd Floor apartment. Service cable is attached at the top of the Stairwell (Fire Escape) just above and to the left of the entry door. This is After the Repair was Completed. Work performed by a Licensed Electrician. Permitted and Inspected by the Local Municipal Inspector. Underwriter Seal from the Independent Electrical Inspector was affixed to the Main Panel confirming code compliance. What say you? Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 2/18/08 at 5:35 PM.. |
Great repair Joe
I would hate to see what it looked like before the "repair." IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Here is a the Handbook graphic showing a very similar setting:
While not as bad as William's it is just another example of what the poco can do because they can. bottom of drip loop is just under 8' 6"
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Just because the 'apparently' inspected it andpassed it and hooked it up, does not, necessarily, mean it is right. This is Chicago, for goodness sakes! When was the last time that a POCO or a municipailty (at least around here) was held liable for not doing thinsg according to their own code. Answer: Never. Different areas, different codes and no one takes responsibility. Except good home inspectors. Hope they are NACHI home inspectors. (That ought to please Nick, eh Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
Some inspectors may not be aware of the code sitations that have been posted.
This is a very good question by the OP and as an inspector myself, I would not pass any of the 3 different situations presented by the different posts here on this thread. Good catch by you guys! |
To clarify. One picture was taken from the ground level and the other one from the 2nd floor porch level.
Sorry for the lack of clarity. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
I was pointing out that even though it is an obvious violation it was still hooked up. It is truly amazing some of the things I see that were "just inspected" by an AHJ. |
| saddle valve placement | relliott | Plumbing Inspections | 11 | 9/7/07 11:22 AM |
| Condenser placement | gheller | Inspecting HVAC Systems | 10 | 4/21/07 11:25 AM |
| Weatherhead help | mmorgan | Electrical Inspections | 14 | 4/30/06 9:54 AM |
