Old 4/22/10, 12:47 AM
Keith Runquist, CMI Keith Runquist, CMI is offline
Send a message via AIM to krunquist
Default Weird GFCI
Any ideas on this. Two year old house. Kitchen GFCI tripped normally with my tester unless I was plugged into the actual GFCI. Then, no trip. The built in test button on the GFCI worked fine. Never seen this before. What would cause it?
Keith Runquist, CMI
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/22/10, 12:52 AM
Bob Elliott's Avatar
Default Re: Weird GFCI
Not grounded.
Old 4/22/10, 12:56 AM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Bingo Bob...I see it all the time.
Old 4/22/10, 3:08 AM
Joe Funderburk, CMI's Avatar
That's why you always test the actual GFCI outlet. Sometimes they show up grounded, but still don't trip. Who knows why. I write it up stating that it would not trip using a dedicated GFCI test device.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 4/22/10, 5:05 AM
Robert Meier's Avatar
Does this mean that it would trip when you tested downstream devices but not the actual GFCI receptacle itself? If so, I agree with the others, the GFCI receptacle itself is un-grounded.
Old 4/22/10, 5:35 AM
Unmoderated Guest
There is no reason for a 2 year old house to have an ungrounded receptacle.
Old 4/22/10, 8:11 AM
mnahrgang's Avatar
I know Joe said he didn't know why, but does anyone else know why that doesn't show up as ungrounded on the tester?
Mark Nahrgang
www.HeyMark.info
Old 4/22/10, 8:32 AM
It can be set up as a false ground .
The others may actually be grounded.
Old 4/22/10, 11:02 AM
rturner's Avatar
rturner rturner is offline
Please Note: rturner is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by belliott View Post
Not grounded.
A GFCI monitors the amount of current flowing from hot to neutral. If there is any imbalance, it trips the circuit. In some areas, upgrading 2 prong outlets (in older homes with a 2 wire electrical system) with 3 prong GFCI outlets is acceptable. Without a ground, a GFCI should still trip. Something else is causing it not to trip.
Some GFCI testers can simulate too weak an electrical "leak" or imbalance to trip some GFCI's.
Did it trip when you mashed the test button?
Old 4/22/10, 6:19 PM
James A. Levy's Avatar
James A. Levy James A. Levy is online now
False ground.
I cant believe I am about to say this but, I...I....I..........agreewithBob.
Old 4/22/10, 6:37 PM
Yes...Yess...Yessssssss
Join me.ha...haaa.haaaaaaa!
Old 4/22/10, 6:42 PM
rturner's Avatar
Sorry guys, I happen to disagree. The GFCI does not use the equipment grounding conductor in the sensing circuit. A GFCI will protect non-grounded circuits and according to the NEC Sec. 210-7(d), GFCI can replace two-wire (ungrounded) receptacles.
Being ungrounded should not cause a GFCI NOT to trip. However, I am still not sure why the downstream outlets will trip but not the first, and I don't see how being ungrounded or having a false ground would cause this either. Please explain!
Old 4/22/10, 8:01 PM
Sloppy work would do it.
Larry Kage, CMI
231 929 3525
Old 4/22/10, 8:05 PM
David A. Andersen's Avatar
Bob, do you think it might not be grounded?!
BPI# 5015804
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 8:33 PM
GFCI Safety Notice rcooke Electrical Inspections 1 10/30/07 12:29 PM
The question asked on the new HI Study test here? jtedesco1 Electrical Inspections 28 10/4/06 9:31 AM
UL Information about Testing of GFCIs jtedesco1 Electrical Inspections 0 2/5/06 4:38 PM
