Old 6/27/07, 4:45 PM
Ian Gills Ian Gills is offline
Please Note: Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Weird grounding issue
Here is a weird one. I recently replaced my two-prong receptacles with three prong self-grounding receptacles. I have armored cable with the strip so there is a good ground through the wall box.
Nevertheless, I tested all the receptacles for a ground using a three light thing which I know most of you detest. Most of the receptacles showed a ground. Two did not, on the same circuit. On this cicruit I installed a GFCI receptacle protecting the second receptacle as well. Here is the weird bit. Now the three light tester shows a ground.
What could I have got wrong with the original installation? If I installed the load and line the wrong way round on the original receptacles would this have caused the grounding problem (surely not since neither was a GFCI)? Or did I attach the wrong neutral to the live on the wall box where there were two sets of wires (but why would this matter on non-GFCI receptacles)?
Or is the GFCI showing a ground? Now that would be silly.
Old 6/28/07, 10:52 PM
Bruce A. King's Avatar
Default Re: Weird grounding issue
Most likely oxidation on a ground connection somewhere.
When you installed the GFCI and tested it with the tester you sent enough current through the ground to cause the resistance to change enough to show a light on the tester.
Have you noticed the "ground" light on the tester is dimmer than it should be?
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 6/29/07, 3:41 PM
Thanks Bruce.
Old 6/29/07, 4:30 PM
tdietrich1's Avatar
How did you bond the three-prong receptacles?
tom
Old 6/29/07, 5:23 PM
tom
...sang "Kum Bai Ya" around the camp fire with them.
Larry Kage, CMI
231 929 3525
Old 6/29/07, 6:54 PM
klott's Avatar
klott klott is offline
Subpanel wired as main panel. jlybolt Electrical Inspections 15 5/23/07 4:10 PM
Demystify Grounding & Bonding Class pabernathy Inspection Education & Training 5 12/24/06 1:10 AM
