Old 7/7/07, 1:06 AM
Gerald C. Wilcox's Avatar
Gerald C. Wilcox Gerald C. Wilcox is offline
Default Were these really electricians?
I called out a subpanel in a garage, because the neutral and grounds were not separated. The realtor mentioned that the electrician said it was no big deal, and left it. I mentioned that there were outlets with open grounds, and the seller said they called 2 licensed electricians that had no idea what I was talking about. I mentioned that they should have GFCI outlets in the kitchen bath's and garage and they installed one in every outlet in those rooms. I called their attention to Double tapped circuit breakers and the electrician says that they do it all the time, it's no big deal. What gives?
Old 7/7/07, 1:19 AM
tdietrich1's Avatar
Default Re: Were these really electricians?
It's a technical term, you were 'blown off'.
I get it too. I've had many heated discussions with actual licensed electricians, and when they say, "Where does it say I can't do that", and I pull out the NEC, they cry "no fair, no one uses the code."
IMHO, you did your job, you documented faults, and when something goes wrong, the odds are they will NOT have the electricians professional options in writing, but they will have yours. Which means you are more likely to be sued, so stick to doing your job right.
tom
Old 7/7/07, 8:53 AM
Michael R. Boyett's Avatar
Originally Posted by gwilcox
The realtor mentioned .... and the seller said....
Do you see where the problem is, maybe?
Old 7/7/07, 9:35 AM
jschulte jschulte is offline
Please Note: jschulte is a non-member guest and is in no way affiliated with InterNACHI or its members.
You might refer them to an electrician and tell them that Uncle Jack and Uncle Steve do not qualify.
Old 7/7/07, 10:10 AM
tdietrich1's Avatar
One way to shut them up, tell the client to get the electricians professional option in writing, to keep a record with their home inspection report (which also is in writing). Should anything later happen, they have a paper trail. I have a funny feeling, the "electricians" will be mum, and someone will rise with creditability.
tom
Old 7/7/07, 12:34 PM
mnahrgang's Avatar
tom
Tom is 100% right. Tell them to get it in writing from these guys on their company letterhead, and then ask the client for a copy for your records as well.
All that "he said, she said" garbage is just that. It's garbage.
Realtors have a saying, "Buyers are liars". What that means is that you can't take what people say at face value. Not necessarily that people are actually unethical and liars (although that's sometimes it), but often people are wrong, don't get the whole story, or are miss-informed. And if the "electrician" who is doing the evaluation is the same "electrician" who messed up in the first place, then what else would you expect...
Mark Nahrgang
www.HeyMark.info
Old 7/7/07, 1:55 PM
William J. Decker's Avatar
tom
I demand this in my report. Get it documented, on the contractor's letterhear, in writing with the contractors license number and insurance certification.
Then, if something happens, the contractor just bought the liability.
I request this be done by the client's lawyer (if they are using one for the closing) or broker.
A few times, problems came up afterwards. I asked if they had gotton the contractor's written opinion. When informed that they had not, I just tell them, well, why should I be held liable for things that your lawyer or agend didn't follow up on, even after I called them out.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 7/7/07, 6:16 PM
tdietrich1's Avatar
WOW two people agreed with me? Must be the 07-07-07 thing!
Two things:
Bill do you have some good standard verbiage for us to see/use?
Second, where are my greenies!!!!
tom
Old 7/7/07, 6:21 PM
Two things:
tom
NO GREENIES FOR YOU!
-The Greenie Nazi
Will Decker, CMI
Old 7/7/07, 7:13 PM
Peter Doane's Avatar
tom
This is exaclty what I always recommend when someone wants to debunk my fiinding. "Put it in writting on letter head with a signature that its ok" Everytime this issue is fixed the way I recommend it to be. For some reson no one wants to sign a simple paper any more??
Thats three that agree with you now Tom!
Peter Doane
NACHI ID# 05120681
Old 7/7/07, 8:04 PM
tdietrich1's Avatar
I went and got me a lottery ticket!
Old 7/7/07, 9:51 PM
I have had many times where a contractor (HVAC, electrician, plumber, "roofer", GC) have called me (after getting a copy of the report) to criticize my statements and try to 'educate' me to their way of doing things.
Every time, I listen to them and let them speak. Then I ask them:
1) Did you do your work according to "best practices" (No, we did it to code and local practice. No one does "best practice". or What do you mean by "best practice".)
2) Were you the lowest quoter? (Yeah, that's the only way you get work. You cut corners, you know how it is.)
3) Will you put your opinion in writing, on your letterhead with your license number and insurance certification? (What's letterhead? What license? What is an insurance certification? Hell no. The job is already done and I don't give no warranties).
Funny how most home inspectors are held to a higher standard of practice and liability than most tradesmen, ain't it?
Will Decker, CMI
Old 7/7/07, 10:27 PM
Thanks, you guys helped me out. Going through this now, and Uncle Jack and Uncle Steve are not going to sign anything.
Thanks again
By the way how do you give greenies?
Old 7/8/07, 1:09 AM
Mike Whitt's Avatar
Unmoderated Guest
As an electrical contractor I have been called to verify the report of Home Inspectors.
When I check what the Home Inspector has called out I refer to the date of installation and whether the item questioned complied with the electrical code at that time.
If the item in question is in compliance with the code at the time of installation I make this statement to the person that hired me for the consultation. I don’t have a problem making the statement in writing on letterhead. By making the statement I am not assuming any liability or implying warranties at all.
A good example would be GFCI devices. When was GFCI required?
1975 for bathrooms, 1987 for kitchens within 6' of the sink, 1996 all kitchen counters, not just those within 6' of the sink but these requirements may have been adopted later in your area.
We all know, and it is a good thing, that most Home Inspectors will call out any of these areas if they don’t see GFCI protection. On the other hand when I am called it is my job to inform my employer that if the installation was made prior to the requirement date there is nothing in NC law that requires them to be changed now.
The same is true with some of the items mentioned in the original post. 250.32 allows for a detached garage to have the neutral and equipment grounding conductors bonded.
It is possible to install receptacles in compliance with 406.3(D) that will show an open ground with plug in testers.
Some manufactures of breakers such as Square D allows their breakers to be double tapped.
It is very possible that the electricians were giving correct information to these people.
Old 7/8/07, 1:38 AM
Christopher Currins's Avatar
[quote=gwilcox]Thanks, you guys helped me out. Going through this now, and Uncle Jack and Uncle Steve are not going to sign anything.
Thanks again
By the way how do you give greenies?[/quote] Click on the yellow star in the right corner. Go from there.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Electricians Check List pabernathy Electrical Inspections 74 12/5/07 7:39 PM
Calling all Canadian Electricians alarsen1 Canadian Inspectors 18 4/12/07 2:36 AM
Tricky Electricians bking Electrical Inspections 27 2/15/07 11:33 AM
VA set to pass its CE requirements to Electricians pabernathy Electrical Inspections 2 11/10/06 8:09 PM
Interesting to Electricians rcooke General Inspection Discussion 0 7/10/06 8:25 AM
