Unfortunately I did not take any photos of this setup.
Yesterday while performing an inspection I noted the presence of a ground rod at the exterior. When I made my way to the basement and began my inspection on the main service equipment I noticed there was no ground wire attached. However I did see a ground connected the the whole house plumbing just a couple feet away from the panel. It appeared as though someone attached the ground wire to the plumbing, ran it outside, then attached it directly to the ground rod. They even ran a jumper around the meter.
Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified |
| Find an InterNACHI certified Maine Home Inspector (and anywhere else in North America) |
We use cold water supply piping for GEC's in Chicago all the time. Sounds acceptable.. Also I have seen both a ground rod and water piping grounding in Chicago.
Thats funny. I saw the same thing last week. New isolated ground panel, and no ground wires on the grounding bar. I looked and realized not ground at all. I went outside and found the same thing. Here in TN they want 2. One on the pipe and one in the dirt. My house was also riddled with problems. Two dumb f@*ks on a sat.
Fogarty Inspection Services Group of Knoxville TN Sean Fogarty Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.homeinspectionknoxville.com |
I don't have a problem with that, often times there is a ground at the exterior (rod) and the interior (water main), but unless your service equipment is connected to that ground it's pointless.
Vince Santos
| Thinking of a New Book - Give your thoughts | pabernathy | Electrical Inspections | 25 | 9/2/09 8:45 PM |
| thinking of offering thermal imaging | pcavalcante | Thermal Imaging, Infrared Cameras & Energy Audits | 6 | 4/29/09 10:40 PM |
| Needed my thinking cap on this one | dandersen | Thermal Imaging, Infrared Cameras & Energy Audits | 7 | 2/15/08 2:58 PM |
| What were they thinking?! (For cat lovers - or haters) | rhumphries | General Inspection Discussion | 7 | 1/11/08 11:17 AM |
| Thinking of becoming a home inspector in West Virginia | David Goad | General Inspection Discussion | 9 | 2/15/07 9:28 PM |
