The home owner upgrade his main panel to 150AMPs. There is a new 1/0 conduit to the meter. I'm suspect the meter is limited to 100 AMPs and I need help to confim meter capcity. If 100 AMP want to make recommendations to upgrade to 200 AMP. Welcome comments.
John Scaparo Innovative Home Inspection, LLC Canton, Michigan 48187 734.664.5853 john@InnovativeHomeInspection.com Michigan Licensed Residential Builder 2101201845 InterNACHI MI #09041012, AHIT Member Plymouth Michigan Home Inspector
Canton Michigan Home Inspector "Helping To Secure Your Home Investment" Looking for link exchange partners. If interested send me your link. |
| Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
If wire is copper, it can service up to 175 amps. Reference Table 310.15(B)(6)of the NEC.
To determine meter capacity, examine the meter and meter base and take them into account. The elements to consider are:
While the meter-base may limit service size, the meter-rating has no bearing on the service capacity of the system. The meter rating identifies the capacity to which the meter has been calibrated.
I regularly see old, "15 amp" meters on modern 200 amp services. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I doubt that the conduit is 1/0. 1/0 is a size for a conductor. Proper terminology helps greatly. Knowing the conductor material makes a difference too.
Like Jeff said item #5 doesn't really matter, and it will not change the size of the service. |
The conductor is 1/0 Copper.
As James mentioned 310.15(B)(6) allows you to used reduced size conductors for 120/240 volt, 3-wire, single phase dwelling services and feeders. #1/0 Cu conductors are good for up to 175 amps in this application. Curious as to why you think that a 100 amp service might require an upgrade to 200 amps? |
| gas meter | dyoung | General Inspection Discussion | 20 | 3/1/10 3:25 PM |
| Gas Meter | dyoung | AskNACHI.org Inspection Questions Forum | 7 | 2/25/10 9:06 PM |
| CPSC -----> Recall on electric meter panels | pbolliger | Electrical Inspections | 0 | 10/15/09 11:23 PM |
| Newer Westinghouse furnaces | jweinberg | Inspecting HVAC Systems | 2 | 7/7/06 12:49 AM |
