I know we have had this discussion before. How many say this light switch is located in a WET location? That is a SPA tub in photo. No shower head.
ENJOY!! Thanks! |
Hi Buck,
code says that it cannot be within the footprint of the tub, that one clearly is, funnily enough had they used a 2 gang switch in the left side of the box it would have been OK. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Gerry,
The local AHJ said it was OK!! I wrote it anyway. Thanks!! |
Buck, local AHJ may say it is ok, but you can always write it up as a safety IMPROVEMENT. By the time your area adapts that code, your client may be looking to sell, and it amy be noted inthat report. good call. Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network INACHI Awards Portal Want To Exchange Links? What we've got here is......failure......to communicate.....
The local AHJ also said it was OK for a condo I was inspecting to have the main disconnect outside, several hundred yards away from the unit, with the inside main distribution panel that had about 30 breakers with no nearby common disconnect(s). Wrote it up anyways as a safety upgrade recommendation.
(1) Readily Accessible Location. The service disconnecting means shall be installed at a readily accessible location either outside of a building or structure or inside nearest the point of entrance of the service conductors. The underlined portion has been debated for years....how far outside is not acceptable...nothing says it has to be on the structure itself and so on....many AHJ's look at it differently.... Paul W. Abernathy |
Does the remote main disconnect have the ability to be locked, this is where the location within sight would play in to this. The 6 throws of the hand would not be relevant to the sub panel location. Also always in question is the distance inside the dwelling you can go before placement of the disconnect must be placed.
| Commercial Inspection Course Dates & Locations Website | dnice | General Inspection Discussion | 0 | 11/4/07 6:12 PM |
| Commercial Inspection Course Dates & Locations Website | dnice | Inspection Education & Training | 0 | 11/4/07 6:10 PM |
| Commercial Inspection Course Dates & Locations Website | dnice | Commercial Inspections | 0 | 11/4/07 1:48 PM |
| Nice One For You - Lesson 1 | pabernathy | Electrical Inspections | 18 | 12/16/06 10:03 AM |
