Having a brain cramp... what's the correct term for the bar that connects across to both bus bars? (Notice how it is bent and the left bus is pulled loose).
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Bonding strap/jumper
Make that "an improperly installed bonding jumper."
Come on Jeff at least it's insulated
LOL! (I told y'all I was cramping)
The rest of the story....... my client's dad and granddad were in the garage while I was showing the panel to my client. When I showed her the concern (keeping her at a safe distance), her dad (before I could blink an eye) reached around and stuck his finger in the panel to touch the "problem" Robert Newland Tyrone, GA 30290 NACHI05101290 http://www.CertifiedHI.com http://www.HomeInspectorTyroneGa.com Home Inspection Reports Powered by: HomeGauge eServices |
That jumper should be horizontal. The terminal bus on the left has slipped downward at least 2". It should be the same approximate height as the one on the right. That would put the jumper out of the way of the live bus stab.
