coming from the main panel?? Hummm...
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
So, what's the answer? I only see a hot conducter. A multistrand cable has nothing that would cause it to "buss"!
Seriously!! Well? Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
My guess was a loose connector. The one wire was oxidized as well,. An empty home with a few lights on. Potentially the main breaker. I just smack the hornets nest and run away.
Why are you guessing? It's not difficult to determine if it's a high resistance connection. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
I have run into this several times. Do you report the buzz sound to your client. I do and write it up as a safety hazard and recommend further evaluation by a licensed electrical contractor. If I hear buzzing before removing the panel I make same recommendation and don't remove the front cover.
What do others do...... John Scaparo Innovative Home Inspection, LLC Canton, Michigan 48187 734.664.5853 john@InnovativeHomeInspection.com Michigan Licensed Residential Builder 2101201845 InterNACHI MI #09041012, AHIT Member Plymouth Michigan Home Inspector
Canton Michigan Home Inspector "Helping To Secure Your Home Investment" Looking for link exchange partners. If interested send me your link. |
Sean that image means very little with out the temp and the amp draw. I see a temp differential between the to incoming legs quite often depending on how the breakers are balanced
Just where was the main service located? The last time I had a buzzing sound it was coming from the main service box located just on the other side of the house wall. The buzz only appeared to be coming from the inside the panel.
David Moriconi
M3 Real Estate Inspection, LLC 816.665.5346 www.m3inspect.com iNACHI Certified Residential Inspector NRSB Certified Radon Measurement Specialist Certified Mold Inspector |
I had heard buzzing before and in one case I found a broken messenger (neutral) on the outside of the home. When that was fixed, the buzzing stopped. This would have nothing to do with this pic as this is a hot feeder.
Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
Loss of the neutral is a major cause of fires. If you ever encounter something like that, the main breaker should be turned off immediately. Loss of neutral can cause 240V to be impressed on 120V circuits.
BestInspectors.Net
& Real Estate Training Academy Inspection Report Software for Windows - iOS - Mac - Android Continuing Education Home and Commercial Building Inspection - Skilled Trades – Real Estate – Appraisal – NFPA 921 http://www.bestinspectors.net est. 1992 |
Sean,
was there a thermal gradiant on the wire? Picture doesn't show enough to tell. |
| Mike New Program starts | rcooke | Canadian Inspectors | 0 | 1/26/11 1:57 PM |
| New house, LOTS of buzzing... | Mark Fiske | Electrical Inspections | 24 | 1/11/09 6:10 PM |
| Noisy (Buzzing) Main Service Panel | thance | Electrical Inspections | 1 | 1/6/08 8:45 AM |
| Buzzing noise from panel | cbrands | Electrical Inspections | 6 | 5/30/07 1:00 PM |
