Old 12/15/07, 1:25 AM
Default What's missing here?
Old 12/15/07, 1:34 AM
mnahrgang's Avatar
Default Re: What's missing here?
Power source?
Mark Nahrgang
www.HeyMark.info
Old 12/15/07, 1:39 AM
Marc Benz Marc Benz is offline
Please Note: Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
if i am right there is no repectale on the outside box on the wall.
and the other thing majorty of them miss one more item is silicone the top and side of box as well to prevent the water get in.
Merci, Marc
Old 12/16/07, 1:36 PM
Pierre Belarge Pierre Belarge is offline
Please Note: Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
Possibly 300.7(B)
Old 12/16/07, 2:31 PM
Getting close!
Old 12/16/07, 8:27 PM
I was looking for 300.5(J)
Here's what it says for underground runs:
"(J) Ground Movement. Where direct-buried conductors, raceways, or cables are subject to movement by settlement or frost, direct-buried conductors, raceways, or cables shall be arranged so as to prevent damage to the enclosed conductors or to equipment connected to the raceways.
FPN: This section recognizes "S" loops in underground direct burial to raceway transitions, expansion fittings in raceway risers to fixed equipment, and, generally, the provision of flexible connections to equipment subject to
settlement or frost heaves."
Old 12/16/07, 9:15 PM
You will find them missing everywhere. I am not sure I have ever seen an expansion fitting actually installed anywhere. Certainly never on a riser like this. I am reminded of the old picture you had of the RNC sticking about 2' past the end of a building, presumably because of expansion. That said, using strategically placed elbows is a way of healing with expansion.
Old 12/16/07, 9:45 PM
how could we have known it was subject to movement?
Old 12/18/07, 3:48 AM
Another example
Old 12/18/07, 9:36 AM
How would we see it during a home inspection?
Abraham Lincoln
Old 12/19/07, 9:11 PM
It would look like this one in this raceway riser, this picture was posted above.
The expansion fitting was installed.
If upon an inspection where the UG conduit was run as a continuous underground run, showing and no signs of settlement or frost heaves, then there would be no concern necessary.
Consumer needs help with missing insulation. gromicko Interior Inspections 4 2/25/07 7:13 PM
Water Heater label missing rnewman1 Plumbing Inspections 3 9/19/06 7:15 PM
Breezway slab & missing support beam. dmacy Structural Inspections 1 6/12/06 9:39 PM
What am I missing? dmacy Electrical Inspections 3 3/2/06 5:21 AM
Missing sheathing jfunderburk Exterior Inspections 2 2/15/06 4:55 PM
