jtaylor5 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would like to know if any of you use infared to read the temperature of breakers?
What is temperature I should begin to question the condition of the breaker, or wiring attached to that breaker? |
Hi ..I had a simular question regarding AFCI breakers the other day .
If that is what you are concerned about I found out they can run around 15 0r 20 degrees hotter. |
Thats good information to have. Thanks.
I have never taken the temperature of a breaker. What should I expect to read from a typical breakers? |
To be honest I will not get heavy into the temp thing, as it may be going overboard .I used my gun because I thought the AFCI's were overly hot.
We got enough to look at. The Flir guys are more into that stuff as part of their routine. Put it this way. Say you run the gun and find a two degree variation. OK now what? If the dishwasher was just run before you got there will it affect your readings? You get my point. |
I agree with not wanting to make more work for myself.
word
Breaker temperatures can vary from low to relatively hot. There really is no "normal" temperature. There are too many variables that would come into play.
Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
I do take the temperature of the breakers too.,, but there are too many way to tell if this is normal or not. kinda like a judgment call on breakers just like the example one breaker will be pretty close to 80 % full load it will show up very warm while other breakers is very low loaded so it will show cooler than others so there is not a really a excat guideline to determed if that is the breaker or connections is overheating you may have to check each one indually to determed if it is normal or not. I am not sure which electrician in this fourm here do have specal camera to tell you the details [ not all of us have it ] so just want to be fair with you. Merci, Marc |
Exactly what I was saying.
Dead subject . |
Hi. Bob; You guys with your fancy toys, ha. ha. I can't afford that luxury, so I still take my electrical panels temperature the old fashion way. Attachment 15842 Check temperature top and bottom of panels. Temperature recorded at top= 72 degrees Temperature recorded at bottom= 68 degrees. I guess I am alright. Improvise!!!!! Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 Last edited by mcyr; 6/8/08 at 3:11 PM.. |
I do it the real old fashioned way, with the back of my fingers. If I can keep my fingers there comfortably, its not too hot.
All right, you guys win, I promise that innovations and technology will inherit the earth, so I will try to follow you guys in this new tool technology.
![]() ![]() On average, approximately one third of all property losses are electrically related. Fully one fourth of those losses are caused by faulty electrical connections. In such cases, loose, dirty, damaged, corroded or oxidized connections and contacts inevitably lead to increased electrical resistance - generating heat and infrared energy as a result. Such problems, given sufficient time, inevitably result in fire or explosion. Identifying electrical threats before they reach combustion or component failure temperatures is becoming increasingly more difficult due to the complexity of today’s building operation systems and control equipment. In addition, the sheer number of contactors, breakers, fuses, and other electrical service hardware make it virtually impossible to physically inspect, shut down, and tighten every electrical connection on any regular basis. With occupant safety, energy conservation, minimal downtime and the protection of capitol equipment all being synonymous with proper maintenance, more and more building operators are turning away from occasional physical electrical checks in favor of the latest preventative maintenance technologies. ![]() Infrared Thermography is ideally suited for detecting faults in electrical panels, breakers, switchgear, splices, insulators, starters, contactors, wiring, distribution systems, disconnects, and transformers, etc. With a lesser degree of reliability, IR can locate water leakage in roofs, steam trap malfunctions, ineffective HVAC air distribution patterns, motor and bearing defects, building energy loss, pipe blockages and underground pipe leakage - providing a visual representation of the heat generated or lost in almost any physical application. ![]() In many cases, the highest temperature value and most defined point within an infrared photograph will identify the actual source of the problem - such as a single bolt, electrical component, or contact surface. ![]() ![]() ![]() Knife Switch - Knife switch contacts present a constant maintenance problem to most older properties. Annual IR inspections of such properties typically find multiple contact problems which can only be repaired by shutting down the equipment, disassembly and cleaning of the contacts, reassembly, and re-tensioning. Upgrading with new disconnect equipment is recommended as the obvious long term solution. ![]() ![]() ![]() Transmission Lines - This 460 volt tower between buildings showed a problem at an old splice. Temperatures were measured at near 300 degrees F., and had charred the nearby wire to bare metal. A combination of weathering, old age, and a less than acceptable wire splice ultimately produced this electrical problem. ![]() ![]() ![]() Knife Switch - Knife switches and most types of sliding electrical contact always present the potential for hot spot problems. Add to them the moisture present in an outdoor environment and serious faults can result. In this example, the A phase of this disconnect switch was found exceeding 350 degrees F. ![]() A typical IR inspection may identify panel doors damaged, mismatched or over rated fuses in place, indicator lights out, inoperative safety mechanisms, as well as various other forms of potential electrical or mechanical threats and liabilities. Unlabeled panels, while not in themselves an operating problem, would likely slow an emergency response to one. Emergency automatic transfer switch (ATS) equipment, tested only in normal mode, would not guarantee proper operation during emergency power. Similarly, testing switchgear and starter panels under little or no load, such as often exists for momentary or standby equipment, would not likely show a problem. Identifying such equipment for special attention during future inspections, therefore, will greatly benefit any building or plant operation. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Some times you learn to count real fast then blow air on your hand. .. Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 293 | 2/10/08 2:20 AM |
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical Inspections | 9 | 4/18/07 8:22 PM |
| Checking temperature of breakers | bking | Electrical Inspections | 13 | 7/28/06 9:45 AM |
| A/C Temperature Differential | cthorsen | General Inspection Discussion | 3 | 7/26/06 2:47 PM |
