Looking for some helpful comments on this.
Thanks. |
Illegal
What shall I arrest this guy for?
wrong choice of wording I guess unacceptable installation method may be better
The wire can overheat , before the breaker trips, creating a fire hazard. |
Since the wire is significantly larger than the lug on the breaker I doubt it could be overloaded. This is simply a listing violation. You are using a wire larger than the breaker accepts and you used an unapproved way to get it connected.
When you have to do something like this for voltage drop problems you splice an appropriately sized smaller pigtail to the breaker. |
It is mis leading as a white wire used as a hot. |
Unless, of course, that this is the size wire that is required for whatever is on the other end.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
If the breaker is labled then you could check the appliance for the required amp draw. It is a 220 30 amp breaker maybe the appliance requires more. 60 amp breaker connector would be sized for the appropriate wire. I can't tell the existing wire size by sight, but I'm sure one of our resident gurus can.
If something really needed a 60a breaker the 30 should trip.
This could be were an existing circuit had a higher ampacity than the new appliance required. The breaker may have been changed to the smaller required size.
As has been said there are much better ways to reduce the conductor size properly. It would be hard to guess what size the conductor has been reduced to or to tell if what remains is appropriate for the ampacity. |
I'm no electrician but I have seen this before and I believe it should be investigated further. It is suspect. JMHO
| Liability question | jcahill | Legislation, Licensing & Legal Issues for Inspectors | 30 | 8/24/08 4:10 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
