Anyone see the problems?
"It's not what you believe that matters...it matters what you believe!" |
| Find an InterNACHI certified Illinois Home Inspector (and anywhere else in North America) |
Yea, Someone left a piece of re-rod and a water bottle in the middle of the floor... What were they thinking!!!
See anything else?
How far are the studs apart
arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
Lack of green wood?
#1 Re-rod is not approved for a grounding rod. It is not adequately buried anyway. Should be outside.
#2 Correct me if I'm wrong, but I don't think the wood is womanized. and it is on contact with a concrete floor. #3 Unsecured wiring. 12-2, prob for an outside outlet, put a few staples in it. #4 If this is an outside wall, why the heck didn't they use cellulose?? Pioneer@homeinspectorpro.com www.pioneerconsultingllc.com https://www.facebook.com/pages/Pione...61954813862888 http://activerain.com/action/agents_secure/my_home Last edited by mroberson; 4/29/09 at 5:03 PM.. |
I think i see a 2x4 stuck under the concrete
That piece of rebar may be the turned up stub from a Ufer ground.
Rebar is used for grounding in almost all modern construction. It's referred to as a Ufer ground, and is the preferred method for grounding a system.
I see no problem here. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I see them often in access panels in garages. I've seen a couple in basements as pictured too.
Exactly...I believe Jim's got it.
Well, unless that wall is going to be built out some more, i do see a slight problem.
You're correct Jim. Apparently your post hadn't been "approved" before I posted mine. . .
Actually Gary, that is the grounding electrode.
Just read up on an Ufer ground, Never needed it here, we have more water here than any other state
| Picture with text software? | bforeman | Inspection Hardware, Software & Publications | 5 | 2/16/09 12:24 PM |
| www.FireDoorInspector.org | gromicko | Commercial Inspections | 108 | 1/12/09 2:39 PM |
