Old 1/31/11, 9:43 PM
Marcel Gratton's Avatar
Default Why...
Anyone can guess why...
On The Level Inspection
Gatineau, Québec
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/31/11, 10:21 PM
rsmith24 rsmith24 is offline
Default Re: Why...
Main disconnect outside at or near meter.
INSPECTIONLOGOS.COM
"I can keep explaining it for you, but I can't understand it for you".
Nick G.
Monroe Home Inspection
Old 1/31/11, 10:55 PM
agallatin agallatin is offline
Default Re: Why...
Box seems crowded .
galaxyhomeinspections.com
An amateur built the Ark !
Professionals built the Titanic !
Old 1/31/11, 11:34 PM
Sean Fogarty's Avatar
Default Re: Why...
Guess what???
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 2/1/11, 11:51 AM
Jeffrey R. Pope's Avatar
Default Re: Why...
Originally Posted by sfogarty View Post
Guess what???
Ditto.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/1/11, 12:01 PM
Default Re: Why...
...a 15 amps breaker is protecting a 8 gauge wire?
Gatineau, Québec
Old 2/1/11, 12:12 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
Default Re: Why...
Marcel, whereas that is not a typical installation, it is acceptable. You can oversize the current carrying conductor, but not the other way. I have seen this done for many reasons. One example would be lets say at one time there was a 240 volt dryer plug, now they did some remodel and moved the dryer to a new location and ran a new power source to it. So they took the old 8 gauge wire and converted it to a normal outlet and accordingly had to put the correct breaker on it. That's just 1 example.
Jim
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Old 2/1/11, 12:15 PM
Michael Larson's Avatar
Default Re: Why...
Not problem as long as the terminal is rated for an 8 AWG wire.
Michael Larson
Hudson, WI
Robert Ernst Robert Ernst is offline
Default Re: Why...
Why? Someone didn't have a 220 breaker? Did someone just use the old wire for something new? Just had the wire on hand? The suspense is killing me.
Old 2/1/11, 12:47 PM
Roy D. Cooke, Sr's Avatar
Default Re: Why...
3rd from bottom left looks like a double tap neutral also .
Old 2/1/11, 1:01 PM
Default Re: Why...
Here's a hint...
Gatineau, Québec
Old 2/1/11, 1:05 PM
Default Re: Why...
Here's a hint...
If you mean the gas range. So what?
They used the 8 AWG to power the receptacle for the clock and control.
Happens all the time.
Michael Larson
Hudson, WI
Old 2/1/11, 1:07 PM
Default Re: Why...
I got that one; now what about that red wire (8 gauge) with the marret...
Gatineau, Québec
Old 2/1/11, 1:08 PM
Default Re: Why...
It's one leg of the unused former range circuit that has been converted to a 115 V receptacle.
Michael Larson
Hudson, WI
Old 2/1/11, 1:15 PM
Default Re: Why...
No big deal abanded in place properly as Michael said Black wire used for some thing else.
