I bet the breaker above it (unused) was tripping too often...
- Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Does seem odd. Many of the Cutler Hammer CH series 15 and 20 amp breakers are rated for two conductors of the same gauge. The fact that these breakers lack the amp rating in black ink on the ends of the handles leads me to believe that they have a bit of age on them (I think they started making black amp ratings in the early 90's. before that they were embossed). Perhaps the empty breaker was nuisance tripping, as you suspect. The Cutler Hammer CH series is a famously high quality plug-on style breaker. It's certainly the most expensive residential panel.
[Edited for spelling] Last edited by Marc D. Shunk; 1/7/07 at 6:26 PM.. |
1979 Condominium...
It's a 20 amp (recessed numbers on the tip)... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
So what do you write during such a finding? Technically, I see no particular violation. It does seem pretty obvious the the above breaker must have had some issue, and the conductor was moved down one. Do you just note this in your report, with no particular remedial action recommended?
"Doubled lugged breaker within the panelboard; It was almost certainly due to the breaker above it nuisance tripping. Monitor for issues with this breaker tripping as well. If such tripping is noted I recommend a licensed electrician replace both breakers (repeated tripping can cause them to trip prior to a real circuit overload) to ensure adequate load is available to all circuits."
is what I have wrote so far... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
What about the use of the white conductors on the devices to the right side?
It looks as though the empty breaker is not of the same vinatge as the others. Close but not quite. It may have been installed later.
I was thinking it's a bit "polished" from the repeated resets (prior to moving the conductor, of course) but it looks as old as the rest in person....
I agree with Joe..those white conductors need to be re-identified and it appears that double tap regardless of the model...appears to have (2) different sizes running to it...but it could just be the angle.
Also I can't tell behind the conductors on the left....but possibly some double luggin goin on with some grounded conductors.... Paul W. Abernathy |
That is the problem with guessing. It could be a breaker that was being saved for a load they never got around to adding, or are taking with them.
Some real estate folks are smart enough to remove some homeowner added stuff before a sale. Where there any KO seals (or missing ones) in the panel? |
Oh yes...never underestimate the WILL of a person who REALLY want's to sell their home...lol
Paul W. Abernathy |
No missing knockouts... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Ok Micheal. You were there. I was not so I'll take your word for it. It might just be the way it shows in the picture but here is what makes me think it was installed a little later.
![]() Not that it really matters for the double tap. |
| Double tapping question | mroe | Electrical Inspections | 17 | 8/30/07 8:32 AM |
| Double Tap Questions | jkogel | Electrical Inspections | 6 | 6/28/07 9:46 PM |
| Double Tapped Breaker | tjohnson3 | Electrical Inspections | 8 | 4/20/07 9:04 AM |
| Doorbell transformer double tap | bsmith | Electrical Inspections | 11 | 4/17/06 12:48 PM |
| Double Taps | rwand1 | Canadian Inspectors | 39 | 3/29/06 7:16 PM |
