Old 9/29/08, 11:34 AM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default Why are these nuts purple?
And what are they used for?
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Old 9/29/08, 11:41 AM
Banned
Default Re: Why are these nuts purple?
Attachment 24309
Approved for aluminum/copper wire "pigtail" splice for older style receptacles.
Old 9/29/08, 12:39 PM
More info:
http://www.alwirerepair.com/burned_purples.htm
http://www.inspect-ny.com/aluminum/i65debat.htm
Larry Kage, CMI
231 929 3525
Old 9/29/08, 1:44 PM
Christopher Currins's Avatar
And that's a winner!! I guess you need to contact Ben to see what you win.
Christopher Currins
Certified, Licensed
Old 9/29/08, 1:46 PM
My bicycle chain broke...
Old 9/29/08, 1:47 PM
Thanks Larry, good info.
Christopher Currins
Certified, Licensed
Old 9/29/08, 2:08 PM
Steven C. Waskewicz's Avatar
Steven C. Waskewicz Steven C. Waskewicz is offline
Jae, I'll bet that hurt
Steven Waskewicz
Colorado Springs, Colorado
719-510-7703
Rest Assured Inspection Services, LLC.
719-510-7703 mobile all the time
Old 9/29/08, 2:42 PM
jkogel jkogel is offline
Why are THESE nuts purple and BLACK?
From Larry's links above.
John Kogel
www.allsafehome.ca
Old 9/29/08, 2:53 PM
Jeffrey R. Pope's Avatar
Ben,
Where did you get the information that these are "approved" splicing methods?
They are UL Listed for connecting CU and AL, but should not be suggested (by an HI) as a permanent repair method for the older AL wiring of the 70's.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/29/08, 3:01 PM
Michael Larson's Avatar
NEWS from CPSC
The COPALUM crimp connector, which has been available for more than 20 years, is the only system recognized by CPSC that provides a complete and permanent repair and reduces the fire hazard in aluminum wire circuits. The COPALUM connector system attaches a copper wire to the old aluminum wires and is then crimped together with a power tool, achieving a "cold weld" between the conductors. The "cold weld" creates a permanent bond that eliminates electrical arcing or glowing connections and creates a safer electrical connection at outlets, switches, lights, circuit breakers, and panelboard terminals. The COPALUM connector repair materials and power crimping tools are only available to electricians who receive training from the manufacturer, to ensure that repairs are properly made.
CPSC #516 (PDF)
Michael Larson
Hudson, WI
Old 9/29/08, 3:05 PM
Mike Whitt's Avatar
Unmoderated Guest
Why are they pruple?
They ran out of pink paint!
Old 9/29/08, 3:06 PM
Dale Duffy's Avatar
Originally Posted by jpope View Post
Ben,
I would NEVER use those wire nuts. I have a picture of one in a house I flipped when I was upgrading everything to CU, I'll try and find it, was burnt like the photo's posted here.
Old 9/29/08, 3:11 PM
Mike Whitt's Avatar
Unmoderated Guest
Attachment 24309
Where did you get your information about these things being good for anything?
Old 9/29/08, 5:07 PM
David P. Valley's Avatar
PURPLE NUTS?
I say no more.
Old 9/29/08, 6:38 PM
http://www.nachi.tv/episode53
Our guest electrician uses them.
And he then demonstrates how aluminum and copper can be improperly connected.
BEN GROMICKO
Wire Nuts in Distribution Panel Skip Erwin Electrical Inspections 12 7/2/08 6:36 AM
Purple stuff bwooddell Structural Inspections 4 9/16/07 6:11 PM
Wire nuts? wward Electrical Inspections 29 2/13/07 8:44 AM
Wanna be a HI...am I nuts? Don Taylor General Inspection Discussion 15 5/7/06 7:17 AM
