Old 2/19/10, 5:09 AM
John Evans John Evans is offline
Default Wired as Sub Panel?
This panel appears to be wired as a sub panel. I did not locate any other disconnect. The original ground was not connected. Very neat wiring, but why separate the neutrals and grounds? Opinions appreciated.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/19/10, 5:19 AM
Default Re: Wired as Sub Panel?
seperation is just workmanship, which is in short supply these days. Pic 3 shows that the neutrals are bonded.
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 2/19/10, 7:16 AM
David P. Valley's Avatar
Looks good to me.
Old 2/19/10, 7:24 AM
Yes, see the upper greenish screw on the neutral buss? It is bonding that buss to the panelboard.
Originally Posted by dvalley View Post
Looks good to me.
Agreed...
Larry Kage, CMI
231 929 3525
Old 2/19/10, 7:42 AM
Thanks to all. Only thing missing is a grounding source. The grounding conducter was coiled above the panel.
Old 2/19/10, 8:08 AM
Jim Port Jim Port is offline
Unmoderated Guest
Like the others have said, personal choice, pride and workmanship. Looks like one of my panels except for the GEC and the tyraps.
Old 2/19/10, 10:26 AM
Jeffrey R. Jonas's Avatar
Pride in workmanship!!! Get that Sparkies name, and keep it on file. You may have need of his services someday.
Old 2/19/10, 11:35 PM
rbero rbero is offline
Send a message via Yahoo to rbero
this is the nices job i have seen in a long time this guy takes pride in his work
Ron Bero
Green Bay Wisconsin
All Star Inspections
www.greenbayhomeinspector.com
Serving Northeastern Wisconsin Including
Brown,Door,Kewaunee,Manitowoc,Calumet,Outagame,
Shawano,Oconto,and Marinette Countys.
Old 2/19/10, 11:39 PM
Bob Elliott's Avatar
Yep
I do not even see any #14.Looks good.
Old 2/20/10, 1:12 PM
We can call it a neat and job with Pride.....However, if he(or she) has not finished what they have started and connect the GEC to the Grounding Electode(s) then he is NOT done and in my mind unprofessional. But in all fairness maybe they are not done yet..
So I will assume this is "NOT" a remote distribution panel for my comments.
Is the opening that the electrician is bringing the GEC into designed for that application?..potatoes...Potatos....probably does not matter for the overall scheme since I really can't tell...
Paul W. Abernathy
Old 2/20/10, 1:49 PM
Unmoderated Guest
Come on Paul, you aren't going to start about whether the 1/4" hole can be used for the GEC now are you? Or are you one of the ones that requires the Kenny clamp on the GEC?
Old 2/20/10, 2:25 PM
lol.....I said I was not going to comment on that...
Funny thing is...as a consultant to a larger manufacture of these types of products ( to go without naming )...they say only the hole provided by them for such a intent can be used. if that hole ( their reasoning ) was put into the equipment as part of their listing for the application then it is fine.... and I dont disagee.
Paul W. Abernathy
Old 2/20/10, 2:26 PM
no....I have not seen any kenny clamps in Richmond, VA
Paul W. Abernathy
Old 2/20/10, 2:30 PM
I guess the question is Mr.Port...lol...is would you allow the contractor to bring his GEC through a mounting hole or if possible a weep hole?..Just because they can.
Paul W. Abernathy
Old 2/20/10, 4:41 PM
Unmoderated Guest
Seems I am not the only one. Somewhere I thought I saw something that said they could be used for the GEC. I will need to look.
http://forums.mikeholt.com/showthrea...ight=weep+hole
or this one
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Electrical for Dummies mcyr Electrical Inspections 16 6/9/08 9:59 PM
Subpanel wired as main panel. jlybolt Electrical Inspections 15 5/23/07 4:10 PM
