Need some advise here.
I am going to install a ceiling fan in the master bedroom. There is no ceiling fixture but there are two sconce lights on the wall. The feed from the panel is #14/2 and there is a #14/3 running between the sconce light boxes. Another #14/2 leaves the box with the feed and goes into the light switch. "I think" I would disconnect the #14/3 and connect the feed to the 14/2 going to the switch and running it into the new ceiling box, then run a new line to the switch so the fan could be switch activated. What do you sparkys think? cheers Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
| Find an InterNACHI certified Pennsylvania Home Inspector (and anywhere else in North America) |
If you can clarify how the connections are made behind the sconces and the number and colors of wires at the switch it would help.
It sounds like you may have a switch loop from the 2nd sconce to the switch, while the power comes into the first sconce. This would explained the 14-3 between the sconces, a constant hot and a switched hot connected to the fixture wires. |
Switch has two wire - black and white Sconce where feed comes in is connected to a red and black and two whites. Seems I forgot to mention that I am removing the sconce lights. cheers Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
I don't mean to offend anyone but, just like you would advise a client to seek professional help i will do the same to you. Call a licensed electrician and pay for a professional job. And so you know I am an electrician
Good advice.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
however I have called at least 5 electricians and none of them want the job Too small I guess thanks Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
Run a 14-3 to the fan so you can switch the light on the fan and the fan itself...and get rid of the wiring for the wall lights.
Thanks for the help Darren cheers Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
| question on wireing furnace, legal or not | Bill Hathaway | Electrical Inspections | 26 | 1/19/07 10:36 PM |
