Cajy Ohone is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have grouped the ends of 8 each 12-2 w/ground wires in the center of my attic that feed various 15amp receptacles (the longest wire being less than 20' in length).
My questions are: 1- What gauge main wire will I need to feed feed these wires from the breaker box that is less than 20' away? 2- What amperage breaker will I need? 3- What type of junction box is required to connect the larger gauge wire to the 12-2 wires? Thank you in advance for any info |
| Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
20 A breaker max.
You have to protect the 12 gauge wire and it is only rated for 20 A. You have a larger problem with the size of the junction box and the wire nuts needed to connect it all. Each junction box is rated for a maxim number of conductors and wire nut connections. Quote:
You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell Last edited by mlarson; 11/8/11 at 9:29 AM.. |
Isn't there a junction box available with a bus bar that I can use?
I also understand that I don't ground this secondary box? |
any idea what size wire I need to feed the junc box?
Agreed! You should call in a electrician for this work if you don't have this info.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
can't afford one if there is someone here knowledgeable with the facts I've stated.
Should be fairly straight up info?? |
You are not understanding something.
The 12 gauge wire MUST be protected by no more than 20A protection. Hire or find someone who understands before you hurt someone. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
EVERY metal box must be bonded to the GES.
OK thanks for the info.
Why am I envisioning multiple pigtails in that proposed box?
I hate to say this, but I hope that is his home, and not that of an innocent!! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
If you dont have the money to hire a professional, dont run the circuits. You likely will just end up hurting someone.
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Don't forget the duct tape.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
Thank you again Mr. Larson and Mr. Pope for the useful information.
To maintain the professionalism of this site I took the liberty of reporting the unnecessary posts such as "I hate to say this, but I hope that is his home, and not that of an innocent!!" and "Don't forget the duct tape". These could be construed as "Taunting" as described in the site rules. The duct tape comment was obviously made to ridicule but the "I hate to say" comment was a direct afront to the safety of myself and my family directed to other than the initiator of the thread.
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| Evaluating your home's wiring system | mcyr | Electrical Inspections | 0 | 12/30/09 1:31 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
