Would you call this out!
Thanks! |
| Find an InterNACHI certified Oregon Home Inspector (and anywhere else in North America) |
arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yes.
Comment - compiled from several sources on this board... Electric panel—Neutral wires installed underneath the same screw. Safety hazard. More than one “grounded conductor” (neutral /white) wire per screw on the neutral bus bar (double tapped/lugged). Each “grounded conductor” is supposed to have it’s very own screw on the bus bar, no other “grounded conductor” or “grounding conductor” (bare copper wire) should be under the screw with the “grounded conductor”. Recommend repair by a licensed electrician. |
Let me take a shot.
I would on the grouped neutrals. The information below I obtained from someone on this board. "Neutral wires are doubled or bundled together on the neutral bus bar. Although common practice in the past, this is unsafe due to the need to turn off multiple circuit breakers to work on any of the circuits using these wires. A qualified electrician should evaluate and repair as necessary." It would depend on the age of the install on the ground and neutral connections. Best to have each neutral on its own terminal and the grounds can be doubled together. Last edited by dmacy; 6/4/09 at 6:15 PM.. |
If there were indications of a neutral being overheated (brown or scorched insulation).
That is not uncommon to see in a older installs. Multiple neutrals concern me more than multiple grounds under one lug though. |
I always call it out but I doubt it ever gets fixed.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
four years old. I called it. Thanks!
Have, do and will.
At any rate, I don't specify a reason. I just tell them it's not allowed by today's commonly accepted standards. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
- Has been a violation going back to the Standard 67 of the UL
- Most panel manufactures require each neutral wire under its own lug EVEN if grouping of ground wires are approved. Peter Doane Realty Check Inspection Service NACHI ID# 05120681
Waddup Pete?
Always.
Hey, Brian and Jeff! WHAT UP!
The grounded conductor is a current carrying conductor. The grounded conductor is energized but has no potential (Voltage) between it and ground. If the connection is lost, there is a potential between the grounded conductor (which is no longer grounded) and ground. Anyone coming into contact with the white wire elsewhere in the house could be electrocuted. The other major problem is that if the two grounded conductors are in contact with each other but have a loose connection to the bus bar, 240V could be impressed on 120V loads (if they are on opposite legs). That's a common cause of electrical fires. The bottom line is that the two white wires under the same screw can cause both a fire and a shock hazard. Licensed Electrical Contractor Master Electrician BS Electrical Engineering Certified Master Inspector BestInspectors.Net License Prep and Continuing Education Home and Commercial Building Inspection - Electrical Plumbing - HVAC- Hydronics - Refrigeration - Fire Alarm Fire and Explosion Investigation - Commercial Sign Installation - Real Estate (Agent and Broker) - Appraisal Inspection Report Software for Windows - iOS - Mac - Android - Linux est. 1992
| Cell Phone Do not call #'s | bjones5 | Canadian Inspectors | 10 | 1/31/09 1:17 PM |
| Last Call for INSPECTVUE SOFTWARE DISCOUNT $845.00 includes Tax...... | jwatts1 | Inspection Hardware, Software & Publications | 4 | 8/8/07 11:47 AM |
| Last call for 2006 pricing for Inspection Management Systems from TheScheduleCenter | gromicko | Miscellaneous Discussion for Inspectors | 1 | 12/20/06 9:22 AM |
