Would you remove this panel cover?
The panel had a tag from the power company that read "hot". Main breaker looks like it is installed wrong and not aligned properly with and cover opening. INSPECTIONLOGOS.COM "I can keep explaining it for you, but I can't understand it for you". Nick G. Monroe Home Inspection |
| Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
As an electrician I would test the cover then remove it.
Anyone else?
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Test cover then remove
As an inspector, I would do the same.
| Do you remove the dishwasher bottom cover? | sfogarty | General Inspection Discussion | 27 | 10/20/09 8:55 PM |
| 100 amp Service w/new 200 amp panel | mlong | Electrical Inspections | 10 | 2/7/08 2:08 AM |
| Need help with main panel board buss bar | smcintire | Electrical Inspections | 63 | 1/8/08 5:55 PM |
