What would you say about a bathroom GFCI that tripped properly with a tester, and reset fine, but the "trip" button on the outlet wouldn't work? Here's what I said, but I'd be interested in hearing what some of you might have said (if anything)...
1.Observed the GFCI outlet in the Master Bathroom has a faulty test button. The outlet was tested using an electrical tester, and operated properly and was re-set. However GFCI outlets should be manually tested every month using this button. It’s failure indicates that the outlet should be replaced with a new one. Minor maintenance repair item. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
| Find an InterNACHI certified Missouri Home Inspector (and anywhere else in North America) |
"GFCI receptacle at the bathroom did not trip properly using the test button on the unit. Replacement advised for safety."
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Both are good.
Jeff Pope provided me with this on a different thread. http://www.nachi.org/forum/f19/gfci-...powered-39889/
