Wiring from a sub panel lacked nail plates, any opinions if you should write this up from a home inspector stand point?
Ok....I will let YOU answer your own question...( trust me it will be fun )
1.) Can you see this as a possible safety concern IF the homeowner finishes off the area and a nail could be driven into the wires? While it is a violation of the NEC if the cable is within 1 1/4" from the edge of the wood stud. To determine if it should be written up.......ok not withstanding it is a "CODE" violation if the hole is less than 1 1/4" from the edge.....take that as a given since HI's are not "CODE" officials....... Now.....you have to look at the area, is it in an area likely to be finished off, is their a possible chance someone could sheet rock the area or finish it off....if YES to any of those....MOST certainly write it in the report to if anything let the BUYER know that IF they plan on finishing the area off they will need nail plates to protect the wires....thats just part of giving the buyer good information...and it makes you look good as well.... And BTW...is a $ 1.50 fix.... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
I guess I should have given a little more info about my question..
1 ) Yes it would be a safety concern if the home owner finishes it. 2) I know its a NEC violation. 3) Yes any area can be finished off with drywall. What a fun game. |
Roy Cooke sr |
OK, I dont feel bad anymore, I slept on it..
Point is my clients should understand that they will have to install plates before the ever finish they're garage, and a Home Inspector should call this to your clients attention.. |
EXCELLENT....NOW you know that was FUN..........Answered your OWN question and I am sure the client will THANK YOU for it.....
| AHJ's opinion differs from code...how would you write it up? | jhugenroth | Plumbing Inspections | 9 | 8/31/09 9:04 PM |
| How would you write This | gporter | General Inspection Discussion | 12 | 9/24/07 3:38 PM |
| Tidbits from the ASHI Message Board | jbushart | Miscellaneous Discussion for Inspectors | 124 | 4/27/07 12:05 PM |
| How should I write this | gporter | Inspecting HVAC Systems | 7 | 6/29/06 4:27 PM |
| How should I write this | gporter | Exterior Inspections | 11 | 4/15/06 10:39 PM |
