The bus bars on this Zinsco had heated to the point that it damaged the mounts. When I removed the cover, the entire setup almost fell out.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 2/28/07 at 4:14 PM.. |
cmccann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Wow Jeff, you are the master!!!
jhugenroth is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yikes!! I see a ton of Zinscos around here, and I always write them up, but the worst I have seen is a little oxidation and some loose breakers. Nothing like that!
I think Jeff lives in the Zinsco capital of the world...would you believe jeff down here in VA I am lucky to see maybe only 2-3 Zinsco's a year( way more Fed.Pacific around here )...and usually they are on the electrical side when we are upgrading them.
Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
I see 10 or 15 Zinsco panels in a month and maybe 5 or so FPE. This was not the worst I've seen, but it's up there in the top ten. . .
I think Zinsco accounts for about half of my inspections, with FPE and the early 1980's Sylvania accounting for another 25%. Murray and GE in the newer homes.
Jeff, I want to move down there. I love seeing those type of deficiencies. And great pic, by the way.
jweinberg is a non-member guest and is in no way affiliated with InterNACHI or its members.
Do you have some standard Zinsco Veribiage you put in your reports that you wouldn't mind sharing with us? It would be greatly appreciated. Jeff |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Jeff "Zinsco" Pope,
Here is a Zinsco from my inspection today. Tons of issues besides being a Zinsco. I especially like the double tapped neutral to the sub-panel; and, the sub panel hot conductors and neutral fed individually through 1/2" romex connectors. Charlie |
If you are unsure and would just rather be safe, this statement is probably the most prudent, and can be used as a general comment for Zinsco and FPE. Quote:
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 2/17/06 at 7:41 PM.. |
The name "Zinsco" is enough "observed" deficiency for me. I don't take covers off simply because of what you noted in your first post and my own experience doing property renovations. I think everything I've ever renovated here in San Diego had a Zinsco panel.
Thanks Jeff...
Jeff, you need to start a zinsco museum.
Is this a zinsco or one of the problematic panels?
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
| WTB: FP and Zinsco | scoslett | Electrical Inspections | 6 | 2/28/07 8:52 PM |
| Zinsco Sylvania | gkoehl | Electrical Inspections | 10 | 2/5/07 6:17 PM |
| Zinsco | cbuell | Electrical Inspections | 4 | 1/4/07 4:31 PM |
| Zinsco panel | jsmith3 | Electrical Inspections | 4 | 3/28/06 8:39 PM |
