View Poll Results: Do you remove the cover from an exterior Zinsco panel?
Yes 62 72.09%
No 20 23.26%
What's a Zinsco? 4 4.65%
Voters: 86. You may not vote on this poll
Old 7/23/09, 11:42 PM
Joe Funderburk, CMI's Avatar
Default Zinsco panels--do you remove the covers from exterior panels?
I've changed my policy. I'll tell you why later.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Find an InterNACHI certified Michigan Home Inspector (and anywhere else in North America)
Old 7/24/09, 12:17 AM
Jeffrey R. Pope's Avatar
Default Re: Zinsco panels--do you remove the covers from exterior panels?
I've never had a problem removing Zinsco panel covers.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/24/09, 12:27 AM
Paul W. Abernathy's Avatar
If in doubt....use the magnets like I use in the Video. But, I remove all panels...with care !
Paul W. Abernathy,CMI,CPI,CME
Old 7/24/09, 1:14 AM
http://www.gregoryinspectionsolutions.com/
Click “HI help” on the left side.
Click “Specialized Advice” on the right.
Click “Zinsco hazards”.
This company is one of only a few sanctioned by the state of NC to provide continuing education to home inspectors licensed in NC (annual continuing education is required and the state dictates where you have to get the training). They provide some interesting information about Zinsco and they recommend NEVER opening covers to exterior Zinsco panels. The writer of this article is a PE with an impressive resume' who, along with his wife, has conducted > 15,000 home inspections.
He says this: "The metal cover extends up toward the main meter and can touch he main meter bus. There is no safety stop to protect you."
Here's his recommendation for reports:
"The main electrical meter panel for this home was originally owned by the Power Company. The inspection panel cover of this panel cannot be safely removed during a home inspection because it was designed to be removed by the Power Company when the meter was off. This ZINSCO panel has known problems with corrosion, and limited availability of replacement parts. Several concerns were noted: (list concerns...such as loose breakers, leaning breakers, visible corrosion, missing door, improper or missing panel labels, no ground rod or plumbing bond, not secure to home or any other visual defect noted when panel was observed NEED ONE TO SEND FOR REPAIR.....) This panel is in need of further evaluation and repair/replacement by a licensed electrician."
Theodore Roosevelt
Joe Funderburk, CMI
Old 7/24/09, 7:24 AM
rbibler rbibler is offline
Please Note: rbibler is a non-member guest and is in no way affiliated with InterNACHI or its members.
I can understand his point. there is no need to go further with the inspection as you have enough information at that point to call for service. Every ZINSCO panel I come across. almost one a day in my area. gets the same boiler plate statement. remove&replace. so why slow down the inspection. I put this statement in every report that is older then 20 years or if I'm just finding a lot of loose connection on the home.
"Due to the age of the home and indication of loose connection, loose outlets of the home you should have a competent electrical contractor pull every outlet and switch, breaker and check all systems for loose connection. Breakers in the electrical panels can have condition behind the breaker at the contact point that can not be noted without removing the breaker and inspecting the back side"
Best
Ron
Old 7/24/09, 8:03 AM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
No I do not remove the cover. I already know that I am going to recommend that they have it upgraded.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 7/24/09, 9:16 AM
Good info to be aware of Joe. We don't have many like this up here. Thanks.
Larry Kage, CMI
231 929 3525
Old 7/24/09, 11:52 AM
(edited due to mis-quoted content)
I've seen a few Zinscos in my time, probably more than most other inspectors. There is only one panel design that has the problem he speaks of;
Don't remove the covers if you feel it's unsafe, but don't rely on bad information.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/24/09, 12:05 PM
Originally Posted by jpope View Post
This is a Zinsco issue? You're kidding, right.
Not sure what it is you think is ridiculous. Perhaps his statement in the parenthesis, which were examples. The "plumbing bond" is probably not the best wording.
Theodore Roosevelt
Joe Funderburk, CMI
Old 7/24/09, 1:24 PM
I mis-quoted that Joe. It doesn't appear that he's relating this problem to the panel after all.
But I still stand on the premise that the information is inaccurate with regards to the panel cover. Out of the 15 (or so) different Zinsco models I've encountered, there is only one where this issue exists. There are other panel brands with this same "deficiency."
The real hazard is presented when replacing the panel cover, rather than when removing the cover. I carry a roll of electrical tape for when I encounter this type of panel.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/25/09, 8:34 AM
Everything in our industry is Case by Case. Nothing ( in my opinion ) is a blanket statement. I have no problem removing Zinsco covers and evaluating the situation and with proper training it should not be a problem.
Old 7/25/09, 4:42 PM
I couldn't agree more. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/26/09, 9:30 PM
This is the reply I got from the owner of the website when I asked them a question about it.
"I am a little closed minded on this because the inspector that I can not poll died in 2007. He was a friend and a great inspector with 20 years experience, he died when the main bus exploded on the panel. I am only referring to the exterior panel once owned by the power company, shown in the photos, there are other Zinsco panel that I find in interior locations, they have defective bus bars, but can be inspected."
Theodore Roosevelt
Joe Funderburk, CMI
Old 7/26/09, 10:19 PM
Alright McGyver, what is the roll of electrical tape for.?
No Zinscos around here, but curious Jeff.
Old 7/26/09, 10:34 PM
Bruce A. King's Avatar
You can tape over the top part of the inside part of the cover for safety reasons. No problem in doing that since leaving the cover off could be considered negligent.
www.BAKingHomeInspections.com
704 301-3207
Kearney vs. Zinsco Service Panels jfunderburk Electrical Inspections 7 12/25/08 2:36 AM
SEC and panels also CEU course material dhostetter Electrical Inspections 3 10/3/08 6:49 PM
Distribution panels bking Electrical Inspections 2 3/11/07 11:29 AM
FPE Panel - Do you open them up? menser Electrical Inspections 11 2/7/06 7:31 PM
