Old 5/16/06, 11:06 PM
hspinnler's Avatar
hspinnler hspinnler is offline
Please Note: hspinnler is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default 12 & 13 SEER Condensing Units
This is a side by side comparison of condensing units installed on new construction. The unit on the left is a 12 SEER, and the unit on the right is a newly required 13 SEER. Both are 2-ton units. Notice the size differences. According to a manufacturer's bulletin, the difference in efficiency between the 12 & 13 SEER units is 9%. As remainding stocks of 12 SEER units are depleted, we will see more of the larger and more efficient 13 SEER units.
Old 5/16/06, 11:10 PM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
Default Re: 12 & 13 SEER Condensing Units
thank you
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 5/16/06, 11:11 PM
Nice info and visual Hank.
Thanks
Old 5/17/06, 9:58 PM
hspinnler's Avatar
Your welcome guys. I re-read the bulletin I received from Rheem and it said that the energy efficiency difference between a 10 SEER and 13 SEER is 30% and 8% between 12 & 13 SEER units. Here's a quick link to the data:
http://www.rheemac.com/13seer.asp
Old 5/17/06, 10:14 PM
Brian E. Kelly's Avatar
Quite an eye opener Hank.
http://www.amana-hac.com/consumer/ch...ases&sub=PRfaq
The majority of the HVAC industry is advocating 12 SEER, why are you going against the industry on this? How could the entire industry be wrong?
Studies show that raising the standard to 13 SEER, translates to a 30 percent savings over present standards on consumers' air conditioning bills and would prevent the need to build up to 138 (300 mega watt size) power plants by the year 2020. Moving to 13 SEER is the most cost-effective way to reduce harmful emissions, keep electric bills more affordable and reduce the need for new generating plants - all accomplished with existing technology in use today.
Old 5/18/06, 12:38 AM
Bruce A. King's Avatar
Some seer 13 and 14 are actually smaller than what you would think....
they can have a double coil setup.
my Bryant/Carrier 3.5 ton is smaller than my 3 ton, both are seer 14 and use R410 puron
Sweating decision:Settle for lower SEER to use existing furnace? Fel Randolph Inspecting HVAC Systems 2 6/6/07 3:56 PM
multiple apt units mbonvissuto Miscellaneous Discussion for Inspectors 2 3/10/07 7:41 PM
multiple apt units mbonvissuto Miscellaneous Discussion for Inspectors 3 3/10/07 2:06 PM
A/C SEER Ratings mjohnson3 Miscellaneous Discussion for Inspectors 0 4/23/06 8:49 PM
Seer 13 Richard Seay Inspecting HVAC Systems 4 2/3/06 9:24 AM
