I have a furnace exhaust and a hot water heater exhaust entering into a y-connection into the chimney. Is this ok? or should one be higher than the other?
| Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The connection is not an issue, the way its connected is. The "Y" fitting should be turned so that the hot water tank vent is above the furnace connection point. If the "Y" fitting were turned a min of 75 degrees clockwise, it would pass code.
If you rotate the fitting 75 degrees then you won't have the 1/4 inch of rise per foot of pipe
Thanks for the help.
If the hot water vent was considerably higher, wouldn't the furnace want to vent off the hot water flue because it is higher and there is less restriction? |
montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
http://hvac-talk.com/vbb/archive/index.php/t-75408.html
This is what I found. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Here,s a post from Febuary of this year. I think you should do some homework on this one. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Number of Powered Vents Needed? | krigler | Exterior Inspections | 2 | 8/8/10 3:14 PM |
| Interesting Roof Vents | cevans | Exterior Inspections | 1 | 6/19/09 2:03 AM |
| Vents in siding?? | sfalvey | Exterior Inspections | 7 | 11/17/07 9:58 PM |
| Gable Vents | mpedeferri | Structural Inspections | 13 | 1/25/06 7:05 AM |
