This unit was changed out obviously after 2008 and had no suction line dryer installed and a undersized liquid line dryer filter Model 053 and should have been at least 163 or larger for a 4 ton. All Techs worth their salt install suction dryers on a burn out I had no knowledge if the old unit was a burn out but most likely was as that is the biggest reason for replacement.
I was unable to call for the addition of the suction dryer but I did call out the under sized liquid dryer. I have bumped heads with the installing contractor in the past for sloppy work and it appears that I will be doing it again Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
trouble maker.....
I had a good teacher You, How is life treating my Buddy
keeping me plenty busy Charley and the snow has stopped so all is good here....
| The Worst Predictions About 2008 | jburkeson1 | Miscellaneous Discussion for Inspectors | 3 | 12/26/08 4:04 PM |
