Old 3/2/08, 9:27 PM
dbucknavich dbucknavich is offline
Please Note: dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default 2x4 in drain pan
Why is this done (2x4's in drain pan)? There were water stains present in one of the pans, and both had the wood in the pans. The house is a year old, with two 5 ton heat pump/air handlers.
Old 3/2/08, 9:33 PM
Brian E. Kelly's Avatar
Default Re: 2x4 in drain pan
Because it is cheap.
Call it out Dylan, even though it is the secondary drip pan it is wrong, they would have been better off using bricks.
Old 3/2/08, 9:37 PM
Prevention of secondary flow right? Wtare stainds were there anyway. Friggin Sunday inspections. I should be watching Family Guy right now.
Old 3/2/08, 9:42 PM
Not blocking of flow so much, as the wood will eventually rot.
Old 3/2/08, 9:45 PM
Hey Doug where did you math answer go, it was good.
Old 3/2/08, 10:12 PM
I missed it
Old 3/2/08, 10:19 PM
tdietrich1's Avatar
I've seen foam blocks, not wood before.
nice.
tom
Old 3/2/08, 10:27 PM
Doug Edwards's Avatar
It was redundant; you beat me to the punch on the right answer. We must have been posting at the exact same time.
Old 3/3/08, 4:00 PM
jking2 jking2 is offline
Probably intended for sound deadening. The HVAC installer will not be around in 3 years when the wood rots away.
Jim King
Inspector in hot water after approving unit without drain rcooke Canadian Inspectors 7 2/20/08 3:59 PM
Child eviscerated by pool drain mthomas2 Ancillary Inspection Services & Additional Topics 26 7/16/07 4:27 PM
Air leak from floor drain yolhovsky Plumbing Inspections 5 2/24/07 6:43 AM
French drain tied into main drain rwashington Plumbing Inspections 6 2/16/07 11:04 PM
