Old 4/24/06, 10:54 PM
jmcclure1 jmcclure1 is offline
Default 410
My father inlaw has had a 410 heat pump and condenser now for two years and I've worked on them two years in a row now. He'll soon be getting a new compressor for his condensing unit this year. Any one else seen any of these yet.
Old 4/26/06, 12:35 AM
jrupert jrupert is offline
Default Re: 410
Sure, R410 refrigerant units are the hottest selling equipment in Ohio
John Rupert
Accurate Property Inspections
Solitaire Heating & Cooling
CSG Training (HVAC Training & Consulting)
Old 4/26/06, 3:10 AM
JLilly's Avatar
JLilly JLilly is offline
Default Re: 410
They've been around for quite a while and more and more are being put in every day.
Old 4/26/06, 9:19 AM
Default Re: 410
Billed as an environmentally friendly alternative to freon.
Old 5/5/06, 8:26 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: 410
On Heat Pumps it is absolutely essential that the indoor coil, if on a furnace, or air handler with coil be replaced together as a matched system. Anything less reduces not only the said efficiency but can lead to compressor changeout problems. Line sets may also have to be changed as well as the required diameter may increase.
Old 5/5/06, 8:43 AM
Bruce A. King's Avatar
Default Re: 410
If only half of the system is replaced, incompatible oils could be a problem.
