Old 11/3/11, 2:23 PM
Richard M. Ross's Avatar
Richard M. Ross Richard M. Ross is offline
Send a message via Yahoo to rross2 Send a message via Skype™ to rross2
Default 410A Condenser and R22 Evaporator Coil
I just inspected a home with a Goodman 410a rated condenser and a R22 rated evaporator coil (Air Handler). The combination has been working for one year and the temperature differential was 14 to 16 degrees F.
What is the down side of this combination? I have received responses from two different HVAC contractors, one said it was ok if a valve was changed and another said it might blow up.
Thank you,
Richard Ross
Accurate Home Inspections of America, LLC
Cape Coral, FL 33914
239-271-8499 Office
239-271-8499 Mobile
407-358-5376 FAX
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/3/11, 3:38 PM
Robert J. OConnor's Avatar
Default Re: 410A Condenser and R22 Evaporator Coil
For something like that the manufacturer should be contacted
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 11/3/11, 6:29 PM
David A. Andersen's Avatar
the metering device is most critical, but generally the design of one coil may not be adequate to replace that of another. it is way beyond anything you can do and it is also way beyond what most field technicians can do. This is a laboratory evaluation and as posted, the manufacturers should be consulted as that's what they do for a living.
Water and air are both fluids but that doesn't mean boats can fly !
BPI# 5015804
