Here’s a good one I ran across this week. Notice the black stained pvc vent pipe. Whenever you this be sure a venting issue exists.
This in particular pertains to the 90% line of Bryant, Carrier, Day & Night and Payne, they are all essentially the same furnace all though other makes could follow the same failure pattern. I spoke with a factory rep and this is a known issue that the stainless steal heat exchanger can fail like this. Carbon monoxide reading in the home 3ppm, in the flue exhaust +700, when we took apart the furnace we found that the secondary condensing heat exchanger was plugged with rust restricting the flow of gases through the furnace, causing improper combustion. Picture #2 is the defective condensing heat exchanger Pic #3 is the new replacement. John Rupert Accurate Property Inspections Solitaire Heating & Cooling CSG Training (HVAC Training & Consulting) |
It's a 90% all right... 90% gone that is... Yikes
Damn...just looking at that thing makes me want to choke.
| Furnace and water heater venting | smcintire | Inspecting HVAC Systems | 5 | 10/14/07 9:27 AM |
| Furnace Venting | bpaull | Inspecting HVAC Systems | 8 | 7/26/07 11:08 AM |
| Furnace and hot water heater venting | sfalvey | Inspecting HVAC Systems | 2 | 4/18/07 1:56 AM |
| Pvc For Furnace Venting? | dtaylor | Inspecting HVAC Systems | 8 | 8/10/06 11:11 PM |
| furnace venting | swalch | Inspecting HVAC Systems | 9 | 2/25/06 10:17 AM |
