Old 9/10/06, 4:55 PM
jlybolt jlybolt is offline
Please Note: jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default What is this?
What is the copper wire for at this evaporator coil? It was all wrapped up with tape.
Old 9/10/06, 7:28 PM
John J. Passailaigue, Jr.'s Avatar
John J. Passailaigue, Jr. John J. Passailaigue, Jr. is offline
Send a message via AIM to jpassailaigue
Default Re: What is this?
I think it might be a refrigerant return line. Should be warm to the touch. I could be wrong on this but believe I am right. I'll be looking for someone else to reply to either back me up or educate me as well.
John J. Passailaigue Jr.
NACHI05062580
Auburn Home Inspection
Auburn, Alabama
WAR EAGLE!
Old 9/10/06, 7:32 PM
Michael Larson's Avatar
Is it as wire or a capillary tube for a control thermostat??
A thermostatic expansion valve ( TXV) is precision device used to meter the flow of liquid refrigerant entering the evaporator at a rate that matches the amount of refrigerant being boiled off in the evaporator, This is it's main purpose but like all the other metering devices it also provides a pressure drop in the system, separating the high pressure side of the system from the low pressure side. thus allowing low pressure refrigerant to absorb heat onto it's self.
More info at:
http://www.hvacmechanic.com/txv.htm
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 9/10/06, 7:52 PM
Thanks for the replies. Micheal I believe you are right. First time to see one of these. Good link. Thanks.
Old 9/10/06, 8:01 PM
adeforrest adeforrest is offline
It looks like there might be a mold problem threr also
Adam DeForrest
DeForrest Home Inspections
Clearwater, FL 33755
NACHI #04091797
dhiofflorida.com
Old 9/10/06, 9:01 PM
David A. Andersen's Avatar
Michael Is Right. For may years, these were installed inside the cased coil. Carrier, Lennox and a few others are now putting them outside.
Mold problem? What is the problem? That is mildew from being wet and cold all the time.
