Old 4/19/07, 2:05 AM
Joseph D. Skrypka's Avatar
Joseph D. Skrypka Joseph D. Skrypka is offline
Default Abandoned Ducts in the attic
The pictures attached show a heating supply duct (or possibly a cold air return duct) in the attic of a circa 1955 home (bungalo) in Toronto Ontario. It was located just inside the attic access hatch. Pictures a little blurry, sorry.
I ran the furnace to see if it was either supplying or returning air and neither case was true (disconnected and / or sealed over the years I guess). I recommended sealing the opening in case a critter found its way into the attic and crawled into the open duct where it there got stuck and met its maker......
Has anyone ever seen this before? I can't see it being a supply duct for an attic air conditioner...... we don't have many of those up here - or at least none that I have seen.
The house has its own A/C external compressor unit (over 20 years old).
Any suggestions?
abandoned-ducts-attic-attic-duct-1-web.jpg   abandoned-ducts-attic-attic-duct-2-web.jpg
Joe Skrypka MBA RHI CMI
The Home Inspection Guy Inc.
Hamilton, Ontario Canada
Membership No. NACHI050062193
Old 4/19/07, 2:25 AM
rmccullough rmccullough is offline
Default Re: Abandoned Ducts in the attic
I have seen it before,, Nothing drastic or even do anything unless it enters the home envelope. Then block and seal it off.
Old 4/19/07, 8:42 AM
Charley L. Bottger's Avatar
I see a lot of kitchen exhaust fans and or bathroom exhaust fans that will be terminated into the attic in this fashion.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 4/19/07, 10:42 AM
I suppose the house is too old for combustion air from the attic??
Abraham Lincoln
Old 4/20/07, 10:24 AM
sparksnmore sparksnmore is offline
Please Note: sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Was the furnace in a closet?
I ask because that looks more like a makeup air duct to supply fresh air to the furnace.
Old 4/20/07, 10:40 AM
bmargiotti bmargiotti is offline
Please Note: bmargiotti is a non-member guest and is in no way affiliated with InterNACHI or its members.
looks like makeup air to me. in that case you wouldnt see much air movement upon operating the furnace
Old 4/20/07, 11:55 AM
The furnace is in the basement. There is no duct termination in the basement that I can link to this duct in the attic, unless it connects with a cold air return somewhere in a wall - which is very possible.
Thanks to all for your responses.
Old 4/20/07, 4:11 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Same here, I see that all the time. Both in round ducts and rectangular like in the picture.
Old 4/20/07, 8:37 PM
bbenjamin bbenjamin is offline
Please Note: bbenjamin is a non-member guest and is in no way affiliated with InterNACHI or its members.
That is simply trash left over from the install which should have been taken out years ago.
Abandoned Attic Unit bkelly2 Inspecting HVAC Systems 7 10/13/07 4:45 PM
Attic Temps mroe Miscellaneous Discussion for Inspectors 12 8/26/07 10:32 AM
Spray Foam to the Rescue ? mcyr Structural Inspections 3 3/27/07 8:29 PM
Attic Inspection rbritton Electrical Inspections 19 8/2/06 3:58 PM
Attic Temperatures Can Pose Serious Risks jtedesco1 Interior Inspections 4 4/2/06 11:17 AM
