Found 2 CAT heaters in a house. These are vented catalytic gas heaters. Do they vent cool enough to use ABS for the vent line? Found them on the internet but could not find an installation book.
| Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
http://ventedcatheater.com/6.html
"Regular Schedule 40 ABS or PVC drainpipe can be used for up to 20' of additional exhaust pipe with up to four 90 degree turns. The exhaust pipe can be routed out of the back of the heater, down from the heater, to either side, or straight up. Care should be taken in routing and connecting the gas line, which should be performed by a qualified person." Could be manufacturer specific and would recommend checking manufacturers installation instructions. Troy Pappas Virginia Beach Home Inspector Professional home inspector serving Virginia Beach, Norfolk, Suffolk, Portsmouth, and Chesapeake 757-418-0944 |
Consult the mfgs. documents. Government is the great fiction, through which everybody endeavors to live at the expense of everybody else. -- Frederic Bastiat |
Thanks - could not find the manufacturer instruction on the internet.
Make and model please.
The only thing isted was the name - the data plate only listed the specs for electric and gas. Could not find anything else - it was installed in about 1971.
The ID or Model plate with serial number are underneath at times. Real buggers. Any small pullout doorway for the pilot and temp control? A little Mirror underneath works at finding those hidden plates with all the information. My bore scope need 3" inches of clearance. A cell phone 1" and time the shot. All the best. Montreal Home Inspection Services Inc. 3510 Benny ave. Suite # 401 MONTREAL Qc. H4B 2R8 Inspecteur Professionnel Certifié en Bâtiment - Certified Home Inspector(CHI) (CHI) InterNACHI Certification ID: NACHI10030603 ACHI Certification ID: ACHI100014 montreal-home-inspection-services.com home-inspectionservices.com home-inspectionmontreal.com Don't get what you paid for Montreal, "Get what you need." Chapter president. Montreal INACHI Peer Group Chapter. |
How funny, I was just about to post nearly the exact same question.
Did a manufactured home last night with a 90% and the intake and flue were both ABS. First time in 8 years I have ever seen that. I assumed on an 90% the temp would be okay but I thought I should check with the HVAC guys on here. Also, does anyone have a good illustration of a 90% intake and flue properly exiting through the roof? Cameron Anderson Bachelor of Architecture, U of I, Urbana IL Illinois Licensed Inspector www.aaintegrityhomeinspection.com |
| Fire caused by Faulty Dryer Vent | nhagarty | Ancillary Inspection Services & Additional Topics | 1 | 3/7/12 8:27 AM |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Air admittance valves everywhere | apfaff | Plumbing Inspections | 13 | 4/16/07 9:17 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
