Some AC units require max. fuse or circuit breaker size of 25 amp. With 25 amp. disconnect fuses and #10 wire, is a 30 amp. breaker in the panel box acceptable?
Question #2: With an AC unit requiring max. fuse or circuit breaker size of 25 amp. is using 30 amp. disconnect fuses, #10 wire, and a 30 amp. breaker in the panel box acceptable? Thanks. |
| Find an InterNACHI certified Massachusetts Home Inspector (and anywhere else in North America) |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
No, the disconnects are generally not overcurrent proitection.
No, max size is 25 amp. |
Thanks Rick.
The reason for question #2 is I don't recall seeing any 25 amp. breakers. |
| 50 amp breaker...what size wire? | jfunderburk | Electrical Inspections | 7 | 6/6/09 5:03 PM |
| A/C Breaker size | dnice | Electrical Inspections | 31 | 9/21/07 3:45 PM |
| Minimum Size Breaker for Sub Panel | rmoewe | Electrical Inspections | 7 | 5/21/07 7:24 PM |
| Service wire size to breaker panel | sfalvey | Electrical Inspections | 12 | 10/31/06 5:28 PM |
| Main Breaker Size | cpennick | Electrical Inspections | 13 | 9/20/06 11:56 PM |
