Old 9/16/10, 12:40 AM
Christopher Currins's Avatar
Default AC clearance
Opinions of dryer vent and sump pump discharge behind AC at right.
ac-clearance-hpim7350.jpg   ac-clearance-hpim7358.jpg   ac-clearance-hpim7359.jpg
Christopher Currins
Certified, Licensed
Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/16/10, 8:38 AM
Kenneth Dolin's Avatar
Kenneth Dolin Kenneth Dolin is offline
Default Re: AC clearance
Not exactly the most well thought out installation thats for sure. The dryer vent could cause future maintenance problems with discharging lint onto the condensing unit coil, but I am not sure if there is any other major concern, Is this new construction?
Ken Dolin
Kenco Home Inspections
WWW.Kenco.org
State of Florida Licensed Home Inspector HI 59
Old 9/16/10, 9:16 AM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
The AC disconnect should not be directly behind the unit.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 9/16/10, 1:56 PM
They are offset a little to the side and I was able to reach them without climbing over or removig anything.
IRC TABLE E4001.5 DISCONNECTING MEANS
Air-conditioning condensing units and heat pump units.
A readily accessible disconnect within sight from unit as the only allowable means.
ELECTRICAL DEFINITIONS
ACCESSIBLE,READILY. Capable of being reached quickly
for operation, renewal or inspections, without requiring those
to whom ready access is requisite to climb over or remove
obstacles or to resort to portable ladders, etc.
Christopher Currins
Certified, Licensed
Old 9/16/10, 4:59 PM
matthew berman matthew berman is offline
Please Note: matthew berman is a non-member guest and is in no way affiliated with InterNACHI or its members.
most mfg. instructions state 10 to 12 inches clear space around the unit for servicing and cleaning and good air flow
Walking surface and wall clearance dbucknavich Exterior Inspections 9 5/27/08 6:07 AM
Clearance Testing tfarmer Ancillary Inspection Services & Additional Topics 15 2/26/08 5:41 PM
Range Clearance dsmith6 Interior Inspections 18 1/7/07 9:55 PM
Service panel clearance wwarner Electrical Inspections 13 8/12/06 12:07 PM
Siding to Ground Clearance tneumann Exterior Inspections 14 2/8/06 11:48 PM
