Old 10/5/12, 2:22 PM
wchandler wchandler is offline
Default AC reset question
What generally is the problem when the AC does not restart when you simulate an overflow by removing the switch and of course then replacing it? Thanks for any info.
www.thebuildinginspector.net
William Chandler
Licensed Home Inspector #1025
Certified General Contractor #CGC060389
HUD 203K Consultant #A0954
Licensed Radon Measurement Technician #R2275
Certified Pollutant Storage Systems Contractor #PCC052624
Certified Underground Utility & Excavation Contractor #CUC057349
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/5/12, 2:32 PM
David A. Andersen's Avatar
Default Re: AC reset question
what are you talking about?
Are you testing the overflow pan switch?
Many units will not come right back on when you interrupt control circuit power. They timeout to allow equalization of refrigerant pressures.
If it never came back on, you did something wrong when you "reinstalled the switch"…
Why are you dismantling anything?
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
David A. Andersen & Associates, LLC
BPI# 5015804
Old 10/5/12, 2:37 PM
John Ritter's Avatar
John Ritter John Ritter is offline
if it is a mechanical float switch and you inverted it,it may be stuck
Old 10/5/12, 4:10 PM
Bruce A. King's Avatar
Did the t-stat display power back up?
Or, if it has no display, can you hear the relays in the t-stat click when you change modes?
When you interrupt the control voltage and reenergize it, it causes a slight surge that can blow a weak fuse in the air handler. Yes, fuses get weak, its called metal fatigue. Some blown fuses are simply "bad fuses" with absolutely no cause other than age. Air handler fuses are typically 3 to 5 amps and often use one of the common types of automotive fuses.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 10/6/12, 2:50 AM
Thanks, Bruce. That's what it was. the t-stat did not display, replaced the fuse and it powered up. Adding fuses to my inventory now.
FYI David Anderson: I check the pan overflow switch as a part of my inspection - don't you? It's a simple and important thing to do and when the unit shuts down, it's easier to remove the AHU door panel to check the A coil - you check the A coil don't you?
William Chandler
Old 10/6/12, 8:16 PM
So what's with this comment?
What do you have to 'replace'?
I know your used to have compliance with the Florida only group, but you don't have to show what a flaming *** you can be...
BPI# 5015804
Four Point Inspection Question (Electrical) khunt Florida Inspectors 43 12/18/11 4:26 PM
GFCI reset location dmacy Electrical Inspections 8 3/31/10 4:00 PM
Sump Pit/Pump Question Joey D'Adamo Plumbing Inspections 4 11/26/08 1:04 PM
