At my inspection today I advised my client that I couldn't start the A/C because of the temperature outside.
He had a large freezer running in the garage and wondered why the freezer operated quite well at low temperature but the A/C could not. It was an unheated attached garage and the temperature, while somewhat above ambient, was still close to the freezing mark. The freezer had been in the garage for several years. Does anyone know why you can operate freezers in cold temperatures but not A/C? |
I believe the freezer is ok because it was running before temperature drop, and was not idle. The A/C is not running so the oil settles in the compressor. Then you start it up and no oil on parts that need it. I suspect you could run the A/C at low temperature if you had it on before it got cold and just left it run. i could be wrong or just not explaining it correctly, but that has always been my logic. Hope that helps. Anyone correct me if I am wrong.
That makes perfect sense. A heat pump [ which as we all know is an AC that goes both ways
Dick Dick Moran True Blue Home Inspections A Div of RAM2, LLC. Clarksville, MD 240-832-6838 MD Home Inspector License 29927 |
Adam Veitenheimer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Also you have to take into consideration that the freezer should be insulated keeping the cold in and apparently the cold out also, so that combined with the fact that it has been running, everything should be ok, hope he doesnt get a blown fuse or power outage for too long of a time...
???????????????????????????????? Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network INACHI Awards Portal Want To Exchange Links? What we've got here is......failure......to communicate.....
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Oil in the compressor does not freeze The major concern about an A/C unit in low ambient temps without crank case heaters is the fact that Freon Migrates to the coldest area of the system which happens to be the compressor where the oil is stored. When you start the compressor that has liquid freon mixed with the oil, the liquid freon can and will damage the valves in the compressor and will also cause the oil to pump out of the compressor. I can go on and on about this but am trying to keep it simple. BTW refrigerators only have oz.s of freon V/S pounds in a A/C unit and do not have liquid migration as they are not a split system. There has to be two areas with different temps in order to have liquid migration. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging Last edited by cbottger; 2/29/08 at 7:12 PM.. |
Adam the coils are outside the unit, not inside with the food.
The original question is very good though ,hmmmm
My garage is insulated and has never gone below freezing it is fastened to the home . -20 F and the garage is at 34. I talked to a repair mechanic and he said the efficiency on the freezer goes down but it does no seem to effect the operation. Mine is only 20 years and works well . Roy Cooke Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Well they remove heat from the air right, so maybe there is something to them running all the time.
Kinda like a running car with no battery. Ok till you turn it off. |
Damn I thought it was Marcel.
Hi Roy Gosh you guys post the same way. Should call both of you Roycel |
Yeah get all tech on me.
| Got a letter from ASHI's President today. | gromicko | General Inspection Discussion | 55 | 12/12/10 11:51 PM |
| Interesting Question? | jmckenna1 | Miscellaneous Discussion for Inspectors | 9 | 11/25/07 1:13 PM |
| Academic Question | jallingham | Electrical Inspections | 10 | 3/29/06 9:16 PM |
