Old 10/11/11, 7:42 PM
Sean Fogarty's Avatar
Default Acceptable?
Hvac wires under compression clamps. No shut off since the main panel was right next to it. Yes or no?
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/11/11, 7:44 PM
Default Re: Acceptable?
Obviously wire nuts were not a good idea..
Different unit
865-256-5397
Old 10/11/11, 8:11 PM
Charley L. Bottger's Avatar
I say yes buttttt I don't like it is not clean there is a better way.
I know yes or no???
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 10/11/11, 8:13 PM
See or Sea what ya miss if you don't take the cover off a electric furnace
NACHI Member
State License # 130
Old 10/11/11, 8:27 PM
Sei Senior!
These were in a quad plex so they all were nasty dirty!
865-256-5397
Old 10/11/11, 8:54 PM
Jeffrey R. Pope's Avatar
This is actually an electrical question Perfectly acceptable even when applied to "HVAC electronics."
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/12/11, 7:31 AM
Robert Meier's Avatar
Judging from the tape job I would suspect that there are split bolt connectors making the connections. They would be fine as long as the conductors are within the listed size range for the split bolt. Also the disconnecting means is required to be within sight of the equipment. The NEC defines that as within 50', so a circuit breaker within a panel can serve as the disconnect.
Old 10/12/11, 8:01 AM
Sucked you in over to the hvac side. Ha Ha
865-256-5397
Old 10/12/11, 11:29 AM
LOL! Kind of slow over on the electrical side.
Old 10/12/11, 12:32 PM
Joseph Hagarty,  CMI's Avatar
Is it not ironic
that the Cable Requirement "to the Unit"
is always greater
than the Cable Requirement "within the Unit"
Why is that?
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 10/12/11, 1:36 PM
Originally Posted by jhagarty View Post
Is it not ironic
is always greater
Why is that?
Because on a electric furnace once inside the cabinet the circuits are broken down or reduced if you would to the single strips which in most cases on average are 20 amps each but there may be 5 strips 5X20=100 amps which is a fair size load for a residential appliance so # 12 with ground is not going to cut the mustard
NACHI Member
State License # 130
Old 10/12/11, 1:44 PM
Roy D. Cooke, Sr's Avatar
Is it not ironic
is always greater
Why is that?
Wires in the air can carry more current then incased wire do to the cooling effect .... Roy
Old 10/12/11, 1:52 PM
Isolation required within / adjacent to the unit unless the disconnect
is within view of the unit\
Joseph P. Hagarty
Phone: 610-399-3675
acceptable humidaty levels in gypsum? ryoung7 Interior Inspections 183 7/21/11 6:31 AM
Acceptable Moisture Levels jkeilson General Inspection Discussion 15 11/9/10 9:02 PM
Example of acceptable deck nailing photos dbonner Florida Inspectors 9 11/8/10 12:55 PM
Acceptable roof rafter repairs ldapkus Exterior Inspections 14 7/17/06 11:49 AM
