Does anyone have info on Kewanee boilers? Out of operation in 2002, but haven't been able to track down much on aging one.
Root River Inspections
Serving Rochester, Winona, Red Wing, Austin, Albert Lea and all Minnesota areas. Vice-President, Southern Minnesota Chapter of InterNACHI Direct: (507)254.1391 Web: www.arochestermnhomeinspector.com Email: rootriverinspections@gmail.com "The nine most terrifying words in the English language are: 'I'm from the government and I'm here to help'" - Ronald Reagan |
| Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
http://burtonmech.com/What_Happened_...html?id=296162 InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Thanks Larry, found that first...just wasn't sure if anyone else has seen/knew about them!
All the Kewanee boilers I ever worked with were 100 years old.
Definitely built in the days of coal but "Use baffles for oil or gas firing". Also can be "Hand fired"..........60+ years old.
The baffles were there and later on they added turbulators to force the flames into a rotation making them the first energy efficient.....lol.
First off, the age of the unit is irrelevant, as the average cast iron boiler in the US last 30 years, (double that, is a good guess).
This boiler is past its serviceable life and should be replaced. I would add a note to the inspection report recommending a licensed professional certify the safe operation before the next heating season. Beyond all this, the boiler shows obvious signs of sustained flue condensate, so the chimney should be inspected as well. |
So how old is it Morgan?
How so?? |
I would guess, 5 yrs. But if you know when the house was built, you know how old the boiler is, since it is the original, yes, coal originally.
The boiler shows stains and the outer firewall jacket has been replaced...I would not have done it. Still stunned by how little regard people have for their own safety and the people that will work on equipment that should have been replaced decades ago. |
| Inspecting Forced Hot Water Boiler help | jscaparo | Inspecting HVAC Systems | 2 | 8/12/10 1:32 PM |
| Boiler Explosion | jvogan | Inspecting HVAC Systems | 14 | 2/11/09 11:41 PM |
| Boiler Control Recall | ldapkus | Inspecting HVAC Systems | 0 | 1/25/07 4:50 PM |
| Boiler Recall | bwiley | Inspecting HVAC Systems | 5 | 12/20/06 6:20 AM |
| Romex on a Boiler? | mgifford | Electrical Inspections | 7 | 1/10/06 4:27 PM |
