Old 2/18/09, 12:42 PM
Dee Stone Dee Stone is offline
Please Note: Dee Stone is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Age-old problem: hot room, cold room
Our house has several. Our HVAC guy was able to crawl around the attic and open/close some baffles to make a few of the hot rooms cooler, and of course we can close the vents in those rooms.
The problem is the cold room (furthest from the unit), which he couldn't improve much at all. He suggested buying a booster vent to pull more air in.
I'm looking for any experience or opinions on how well these work. Here's one I'm considering:
http://cashmoneylife.com/2007/11/28/...-vent-booster/
Old 2/18/09, 1:30 PM
Brian E. Kelly's Avatar
Default Re: Age-old problem: hot room, cold room
FH-209 Space Heater 90 Degree Oscillation
Thermostatic control and 4 temperature settings make this heater/fan an excellent choice! >> More Info
List Price: $39.95
Our Price: $29.99
Old 2/18/09, 11:12 PM
David A. Andersen's Avatar
Where do you live?
Describe your house style.
Number of units.
Location of return(s).
BPI# 5015804
Old 2/20/09, 7:34 PM
Jeff Merritt Jeff Merritt is offline
A booster fan installed inside the duct work is better than the one you are looking st, it works off a pressure switch, your HVAC contractor should be able to install it, you will have to get an electrician to run power to the unit. make sure you get a a good unit, cheap ones make a lot of noise.
Old 2/20/09, 7:56 PM
Harry E. McClard's Avatar
Harry E. McClard Harry E. McClard is offline
I agree Jeff. I installed one of those at home; cost about $30 for the fan plus electrician. Worth every cent spent; quiet, can't tell it's there except my basement office (that's where the cold spot was) is much warmer now.
Harry "Bud" McClard
Serving All of New Hampshire
Old 2/21/09, 9:31 AM
mnahrgang's Avatar
I had that situation in an office I worked at. My office was the furthest from the thermostat. The duct work ran through a cold plenum, so the stagnant air in the ducts was very cold too. When the heat kicked on, it first had to blow out all that cold air into my office. About the time the warm air got there the rest of the office had already heated up and the thermostat kicked the furnace off again. My office just got colder. The only solution available at that time was to close off the duct and install a space heater. Don't know what the supplemental blower might have done. I suspect the initial result would be the same in that it would blow a bunch of cold air into the room first, but then it would at least have some time to blow some hot in their too.
Mark Nahrgang
www.HeyMark.info
Old 2/21/09, 9:49 PM
kweiss's Avatar
kweiss kweiss is offline
Is the room hot in the summer too? If so it could be a building envelope problem. If it is a duct routing problem, a booster might be a good option, don't have personal experience with them, but have considered one for a problem in my own house.
Kevin Weiss
Professional Inspector
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Hot water first then cold out of cold side of fixture jberthiaume Plumbing Inspections 19 3/12/08 1:32 AM
Moisture Problem..Attic Tim Fogliani Structural Inspections 13 1/9/07 6:33 PM
cold climates: insulating floors w/plumbing above cold crawlspaces kshepard Plumbing Inspections 6 9/25/06 11:09 PM
Exhaust fan in room with gas water heater and furnace jweinberg Inspecting HVAC Systems 7 2/18/06 1:23 PM
