Gotta love it
Y' know what I think?
I think that agent was trying to spoof you. That's what I think. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
What is that thing???
Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
I'm not sure what we're looking at here. Possibly a consenser fan motor that was changed, and the splice is in free air there, taped up in a big wad? Not sure.
I think he meant A/C is code mandated in Florida???
It is a replaced fan motor with the wires taped
Can not tell from the pic but If I was guessing would say beneath that mess of tape you would find not a splice but a rubber boot for rotation change. Most contractors do not use OEM parts unless no other choice. Universal condenser fan motors most usually have the two wires and rubber boot for this. The boot should have been strapped to the bracing of the motor to keep it out of the blades within the housing not external. I always used electrical wire ties to fasten the boot not electrical tape because tape will unravel due to moisture.
Let me ask a question here while we are looking at the condenser fan. How can you determine which direction a fan blade is suppose to rotate while observing it in the idle state. There is a hard fast rule with no exceptions </IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
This fan blade is to spin clockwise facing the discharge:
and this fan blade is to spin counter-clockwise facing the discharge: Note also that if the blade itself has any "curve" or "dish" in it, the concave side is the discharge side. The images both show the discharge side up in the pictures. |
I guess I'll have to make an appointment to get me some new glasses.
Another way of saying the same thing as Marc is to look at the high side of the blade..if it's on the left then the blade must spin clockwise to push air up; if it's on the right then it spins counter-clockwise. Even another way of saying this is if when looking at a spinning fan blade then the trailing edge of the blade indicates the direction of airflow.
To get back to the original ball of tape I don't think you will find poor quality workmanship addressed in any code book. I personally would have handled that issue just as a safety issue and been done with it. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
| Got a letter from ASHI's President today. | gromicko | General Inspection Discussion | 55 | 12/12/10 11:51 PM |
| What is your HVAC procedure? | sstowe | Inspecting HVAC Systems | 66 | 5/28/09 12:48 PM |
| Missouri Passes New Law to Protect Consumers....from RE Agents | jbushart | Legislation, Licensing & Legal Issues for Inspectors | 0 | 7/17/07 7:38 PM |
| Now REAL ESTATE AGENTS are required to do code inspections | dpeterson | Legislation, Licensing & Legal Issues for Inspectors | 10 | 5/31/07 9:05 PM |
| Importance of the AHJ check | mcyr | General Inspection Discussion | 6 | 2/21/07 8:18 PM |
