Jerry Gilles is a non-member guest and is in no way affiliated with InterNACHI or its members.
I leave in Florida. Need to condition a room nd the only practical way is to run a duct from the garage wall (separating the living room) to the room in question. I know that that wall is a fire wall and need protection. But can the Florida Mechanical Code allow for a duct to run thru the garage?
Jerry Gilles |
| Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Approved material and sealing , Depends on local code enforcement . should be some Fl boys along shortly
As Wayne said or box the duct in and remove all doubt.
Installing a fire damper would be even cheaper.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
You would need two.
Thank you, guys. But I am waiting for some input from Florida.
Jerry |
Call a reputable local HVAC company to do the work, and file for permits to make sure you are meeting the applicable local codes and safety requirements. Anything else is basically just a guess at what your local requirements are and the propper way to complete the work.
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Of course I do for krist sake. That was an assummed statement that if you have on on the entrance, you have one on the exit.
But one will be lucky to find a 26 gauge duct if at all. I am lucky to find drywall separations up here. Only on new construction do I see it. I would also like to see a smoke activated damper if that were used anyways. Doubt if I will ever see one. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Would it still be cheaper than boxing it in with sheetrock? I suppose it depends on who does the work. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Considering the duct insulation, the framing, drywall, fire taping. Yes cheaper to have a damper activated by a heat detector since the smoke detector would not work due to car exhaust.
Good info, thanks Marcel.
Buy one like this for $100 You can get more sofisticated by having one with a heat detector tied in with the rest of the house system, heat detector in garage would activate it. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Hey Marcel , do they still use the heat links anymore?
| Garage concrete slab question | jjonas | Structural Inspections | 9 | 8/31/10 3:18 PM |
| Garage Fire Wall II | bhartley | Interior Inspections | 3 | 9/19/09 7:25 PM |
| Wall Vent in Garage | psigler | General Inspection Discussion | 2 | 8/8/09 12:37 PM |
| Moisture Management | mcyr | Exterior Inspections | 15 | 9/8/08 12:11 PM |
| Fire wall | tyeager | Structural Inspections | 38 | 8/24/07 11:17 AM |
