Old 11/1/10, 4:46 PM
Gary T. Heller's Avatar
Default Air filtration
This is a split system heat pump with the return air chase at the bottom of the air handler in a hallway closet. The unit was working properly but there is quite a bit of dust accumalation in the return air plenum and one filter installed and one filter missing.
My question is the device in the photo. It is made by Honey Well and has enviracare written across it. Anyone familiar with it? Is a some type of electric percipitator?
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/1/10, 4:56 PM
Stephen W. Stanczyk's Avatar
Default Re: Air filtration
Electronic Air Filter. They work great especially if you have allergies. Behind the cover there should be 2 aluminum screen filters and 2 electronic filters. Turn the unit off, remove the cover and inspect the filters. If they are dirty, just put them in the dishwasher and run a full cycle. Drip dry and re-install.
Stephen Stanczyk
Old 11/3/10, 8:48 PM
Kenneth Dolin's Avatar
Kenneth Dolin Kenneth Dolin is offline
Yuppers, those things are great, especially when coupled with a UV light, the combination eliminates virtually all allergens in the system.
I have no idea how to actually test the unit, I just make a notation about the presence and the physical condition and that is was not tested further than that.
Ken Dolin
Kenco Home Inspections
WWW.Kenco.org
State of Florida Licensed Home Inspector HI 59
Inspecting a Water Filtration System sshockley Plumbing Inspections 2 6/20/09 3:08 PM
Air filtration system enorthe Inspecting HVAC Systems 7 4/26/09 6:04 PM
MERV Efficiency Rating for Filters Brian A. MacNeish Inspecting HVAC Systems 21 1/6/09 4:27 PM
CPVC Water Filtration System dhubler Electrical Inspections 5 11/15/08 5:34 PM
How to install a water filtration system? dmacy Plumbing Inspections 22 6/30/08 8:16 AM
