Old 12/2/10, 11:06 PM
pnarron pnarron is offline
Default Air Handler
This unit is 24 years old and I dont know how long the plywood has been used. I'm putting in the report that HVAC system is at the end of its useful life and she should budget for new units in the very near future. Would it be a health issue with the plywood? (foreclousure)
Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/3/10, 8:40 AM
rsmith24 rsmith24 is offline
Default Re: Air Handler
Inside the wooden box is most likely lined with sheet metal just like a wall cavity.
INSPECTIONLOGOS.COM
"I can keep explaining it for you, but I can't understand it for you".
Nick G.
Monroe Home Inspection
Old 12/3/10, 8:52 AM
Charley L. Bottger's Avatar
Most areas allow wood on the return side of a system but never on the supply side. (Temp differential)
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 12/3/10, 8:56 AM
Banned
Or not.......it may be better practice to have a metal plenum or metal liner but if just wood with that moisture staining + rust on the unit, I'd have concerns.
Old 12/3/10, 9:09 AM
At 24 years of age my guess would be the A-coil drain pan was leaking down into the return plenum
NACHI Member
State License # 130
Old 12/6/10, 6:20 PM
agallatin agallatin is offline
Phil would be nice if you had a pic of the whole HVAC . So we could see more about the moisture staining . An if there is no air into that box other than what we see , it would be a good place for spores to collect and start to grow (with the moisture leaking down). The set up looks mickey mouse !
galaxyhomeinspections.com
An amateur built the Ark !
Professionals built the Titanic !
Electric air handler wiring jfrederick Inspecting HVAC Systems 4 7/16/10 9:11 AM
Air Handler sshockley Inspecting HVAC Systems 16 1/26/10 9:29 AM
Armstrong air handler age? amccormick Inspecting HVAC Systems 2 6/2/09 7:01 PM
Air handler question lking Inspecting HVAC Systems 5 8/25/08 10:11 PM
Goodman Air Handler runs 24/7/365? Michael McDonald Inspecting HVAC Systems 14 3/27/08 2:42 PM
