Old 8/22/06, 10:59 PM
nbhi's Avatar
nbhi nbhi is offline
Default Air handler
Can anyone give me advise as to how you would handle inspecting a air handler? No gas, No burners to inspect, etc. What do you look for? Do you disassemble?
Regards
Gary
Attachment 5210
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 8/22/06, 11:03 PM
Michael Larson's Avatar
Default Re: Air handler
Is this an electric furnace?
Old 8/22/06, 11:05 PM
nbhi's Avatar
Mike, Yes this is electric
Old 8/22/06, 11:10 PM
Verify that it responds to the command of the thermostat and produces heat. There should still be a filter to check. Unless you want to measure if the heating elements are all functioning(beyond the scope a typical Home Inspection) That's it.
Old 8/22/06, 11:11 PM
Is this the only heat source in the building?
Old 8/22/06, 11:26 PM
nbhi's Avatar
There is a wood burning fireplace. Other than that no.
Old 8/23/06, 12:09 AM
nbhi's Avatar
What are their capacity rated at? Unlike a gas furnace, BTU'S
Old 8/23/06, 12:23 AM
Watts x 3.413 will give you BTU/Hr
1500 Watts is about 5,000 BTU/Hr
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 8/23/06, 12:33 AM
nbhi's Avatar
Mike
Can you tell by the label what wattage? I can not locate.
Old 8/23/06, 12:38 AM
Mike
I tried but the picture is not clear enough. I think there are at least 2 heater circuits at 240 volt. The Circuit breaker cabinet might give you some help. If you have the model number, try looking it up on the manufacturer's site using google.
Michael Larson
Hudson, WI
InspectraPro
and
Old 8/24/06, 2:41 AM
David A. Andersen's Avatar
Any labels will indicate several heat kits that can be installed. You have to take it apart to find out unless the installer marked it.
Or as posted convert Amperage to BTU's.
Ducane Heat pump and air handler dates?? tallen Inspecting HVAC Systems 19 12/30/09 4:11 AM
Is the York Air Handler condesate pan obsolete? Ruth H. Frazer Inspecting HVAC Systems 10 8/10/07 7:28 PM
Electric Air Handler - Heat Pumps Scott Schultz Inspecting HVAC Systems 9 5/24/07 2:55 PM
air handler issue acooke Inspecting HVAC Systems 3 5/8/07 9:30 AM
