Go Back   InterNACHI Message Board > Specific Inspection Topics > HVAC
HVAC Topics include heating, venting, and air conditioning.
Old 4/8/09, 3:52 AM
Linda J. Foster's Avatar
Linda J. Foster Linda J. Foster is offline
Unhappy Air handler supports
Saw an electric heat pump split system today.
When the air handler with heat strips is located in the attic, do the supports for the unit need to be non-combustible material? This was mounted on a wood frame instead of a concrete blocks, etc.
I assume (???) they would non-combustible for a gas furnace,,, but what about electric?
Thanks,
Linda Foster
www.HomeInspectionsByFoster.com
HomeInspectionsByFoster@yahoo.com
(210) 347-1023
TREC #7654
InterNACHI #06032691
Find an InterNACHI certified Texas Home Inspector (and anywhere else in North America)
Old 4/8/09, 8:54 AM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Default Re: Air handler supports
Typical attic installation here is metal tray (with drain or overflow protection), 2x4 blocks in pan with air handler on top.
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Old 4/8/09, 10:42 AM
At some point in the not far past, I thought the unit had to be standing on non-combustible base in the pan. Couldn't find the reference when I got to looking.
A good many we see have some type of brick or block supports.
Linda Foster
(210) 347-1023
TREC #7654
Old 4/8/09, 11:17 PM
I see virtually all attic air handlers on wooden supports around here regardless of fuel source. While there may be a code to the contrary, IMHO the outer casing/frame of such units is so far away from the heat source as to make it a non-issue. If high-temperature energy should penetrate the enclosure there is so much more cumbustible material in an attic to worry about. That's why in my personal home, I have smoke detectors in the attic reporting to my alarm system.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 4/9/09, 12:12 AM
Chuck Evans's Avatar
Should be OK for electric
Air handler question lking HVAC 5 8/25/08 11:11 PM
Goodman Air Handler runs 24/7/365? Michael McDonald HVAC 14 3/27/08 3:42 PM
supports rcantrell Structural 8 10/11/07 12:17 AM
Crawlspace supports bclark Structural 2 4/19/07 9:00 AM
Attic supports hcavin Interior 2 4/5/06 10:56 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
