Old 2/27/07, 11:15 PM
sfalvey sfalvey is offline
Default Air in hot water baseboard
How would you guys report hearing air in a hot water baseboard system. I know it shouldn't be there, it certainly doesn't warm the house up as good as a solid flow of water.
Input please.
Thanks.
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 2/27/07, 11:41 PM
Charley L. Bottger's Avatar
Default Re: Air in hot water baseboard
Input please.
Thanks.
If you truly have air as you suspect. Report it just as you would any other defect its not suppose to have air in the system. I like the word (appears) to have air and recommend that it be serviced by a heating company.
You don't suppose it is a water hammer do you just a thought.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 2/28/07, 12:25 AM
jschulte jschulte is offline
Please Note: jschulte is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hot water heat systems need to be bled on occasion. It is not uncommon and part of regular maintenance. There should be a valve at the radiators that can be opened slowly until the air escapes and water comes out. This may need to be repeated several times.
It also helps to make sure that the water supply to the boiler is on.
Old 2/28/07, 12:31 AM
Jeff I thought the question was baseboard heat not radiators to me these are two different systems????
NACHI Member
State License # 130
Old 2/28/07, 12:38 AM
They are the same to me. They both are run with a boiler and both have valves to bleed the air (My current house has radiators, my former house had HW baseboard.) I believe the baseboard models are just the current fad (however current boilers are??)because they are out of the way.
Old 2/28/07, 12:49 AM
I would label as similar in operation only; walk into a supply house and ask for a baseboard heater and they bring you a radiator are you going to be happy???
Yes I agree they all get air in the system and need to be bled if the plumber did not forget to install the bleeders???
I would also agree that this is a maintenance item but is not performed by the HI
</IMG></IMG>
NACHI Member
State License # 130
Old 2/28/07, 1:13 AM
</IMG></IMG>
I don't do any maintenance, but I would be happy to tell someone how to do it.
If the plumber did not install the bleeders it still needs to be done, you'll just have to have bleeders installed first.
Old 2/28/07, 10:16 AM
bandag bandag is offline
Please Note: bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
I had a home with gas hot water baseboard heat. there was a little hammering at first start up, not much. There was a bleed valve at the furnace, sort of like a valve stem on a tire, (but not rubber) had to bleed it manually once or twice a season. no bleed valve on the baseboard system. worked fine.
Old 2/28/07, 10:25 AM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
Bleeders are not required at the radiators! I just don't want anyone to think they are.
The system with out bleeders (at the radiators) would be bled by closing off each zone, attaching a hose to the Purge & Balance Valve (some may call this a bleeder valve) at the boiler.
I'm not going to explain the whole process here, but you do waste a lot of water this way. Although it isn't a bad idea to flush the old water out of the system once in a while.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
